4cyl
Old Mar 4, 2008 | 09:10 PM
lsu03's Avatar
lsu03
4cyl
can you pull anything frequently(2-3 times a week, only about 20 miles) with a 4 cylinder?
also, could you fit two kids along with the driver in a single cab? with auto? with manual?
Old Mar 4, 2008 | 09:24 PM
jimdandy's Avatar
jimdandy
#1. Yes, if the load is reasonable. The truck is rated at 1000 lbs., but it will sit very low with that much weight.
#2. Yes, if you don't have buckets.
jd
Old Mar 4, 2008 | 09:33 PM
lsu03's Avatar
lsu03
the few i am looking at have all benches.
Old Mar 4, 2008 | 09:52 PM
sfcwoodret's Avatar
sfcwoodret
Pull a small utility trailer.
Old Mar 5, 2008 | 12:51 AM
Bear River's Avatar
Bear River
Former ******
My dad has one, and if you have the 5 speed, they seem to pull fairly well. Obviously you won't be going up any hills at 85 mph, but you will still reach your destination in a timely manner. I would be more careful with the auto. The A4LD based trans can handle the loads, but requires more maintenance and you shouldn't use overdrive when going up hills.
Old Mar 5, 2008 | 03:28 AM
pgw85706's Avatar
pgw85706
Make sure everyone has a seat belt.
Old Mar 5, 2008 | 08:00 AM
seasterday11's Avatar
seasterday11
yes u can I have a 4cyl 97' ranger and I deliver furniture in it 3-4 times a week and everyday I run it at least 60 miles a day
Old Mar 5, 2008 | 08:30 AM
sfcwoodret's Avatar
sfcwoodret
Gear it down and have a low gear rear end.
Old Mar 5, 2008 | 11:14 PM
Randomtasker's Avatar
Randomtasker
Although I have been ridiculed, I pull a 14' enclosed haulmark trailer behind my 88 ranger. I have the 2.3 l 4 cylinder. It does great around town, but stinks on hills and highways. Milege is great though compared to my F150 and F250. (V-8's)
Old Mar 7, 2008 | 09:55 PM
yompe's Avatar
yompe
i have a 2000 2.5 4cyl 5 speed with a 4.10 ls 8.8 235-75-15 tires open exhaust tb spacer jet chip k&n intake and i tow my pop up camper that weighs 2000 lbs with elc brakes all over the nc mountains with no problems
Old Mar 8, 2008 | 08:43 AM
wendell borror's Avatar
wendell borror
Yeah, everyone has to have a seat belt or it's illegal not to menton dangerous. At best you will have belts for 3 in the front seat. I would not recomend 4 of any age, safty must allways be the first priority with your kids. Sounds like you need a supercab with the jump seats in the rear for children and they have seat belts. Proper gearing makes the difference when towing with a 4 cylinder, no less than a 3:73, 4:56's would be ideal. However 4:10's will give you the best of both worlds, great torque and still real good mpg.
Old Mar 8, 2008 | 11:04 AM
lsu03's Avatar
lsu03
can you get any 1/4 ton truck with an extended cab and 4cyl engine?
Old Mar 8, 2008 | 11:31 AM
wendell borror
I don't know about any truck, but you can get a ranger with a supercab and 4 cylinder engine, either automatic or manual tranny. Sounds like thats the direction you really need to go, it will also give the adults in the front more room so everyone has a comfortable safe ride and it will still tow the same. Kids get a kick out of those jump seats in the rear, plus thier facing each other so they can kick fight, play and whatever else youngsters do to entertain themselfs. It will also give you added room for groceries or whatever if the weather is bad, so you won't have to carry them in the bed.
Old Mar 8, 2008 | 12:41 PM
lsu03's Avatar
lsu03
do they have many used, older trucks like that?
Old Mar 8, 2008 | 12:54 PM
khadma's Avatar
khadma
Carpenter Local 745
Older Rangers can be found with great "hauling" running gear. Even with 4 cylinders - back in the day, one could special order just about anything one wanted in a truck. Oh I wish those days were here again, anyway, Ebay, craigslist, cars.com(?), etc, etc, maybe your only sources for older trucks.
IF you are going to get one, better make it soon. These trucks won't be around much longer.
