Fuel additive
I have a 99 7.3 and would hate to mess something up.
Technically you do not need to. ULSD is supposed to have all the additives it needs to provide proper lubrication and such from the refinery. Some folks worry about it though and run additive every fillup just to be on the safe side.
The way I look at it is it doesn't hurt to run the additive, so if you want to, go for it, but it's probably not necessary. I tend to add some to mine just once in a while, or whenever I'm going to the snow (cold weather).
Powerservice's Dieselkleen is one popular brand... another is Stanadyne Performance Formula.
I would suggest trying a couple of different additives and if you can see a fuel mileage increase then stick with the additive. If you don't then it's up to you. If you happen to run any biodiesel then that already has better lubricity than any of the additives.
One word of caution. Both the Dieselkleen and Stanadyne bottles tend to leak once the seal has been punctured. So don't throw an opened bottle anywhere it might drip out and stink up or ruin something.
Here's the Spicer report I referred to:
http://dieselplace.com/forum/showthread.php?t=177728
http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
I run Schaeffer's Dieseltreat diesel fuel additive.
http://schaefferoil.com/diesel_treat_2000.html
P.S. Joe (Izzy351)- check your cell phone messages man!!! What's up for the 15th?
Anyone reading this around the DFW area (or further out, if you want to make the trip!!) that doesn't get the NTxPSA messages, there is a dyno event being put on by Bully Dog in Denton on March 15th. I live a couple miles away from it, so I'm planning on going and spinning the rollers...
I personally use the Schaeffer's Diesel Treat 2000. I bought a 4 gallon case, and then sold 2 of the gallons to some of my diesel owning friends. Since every gallon of it treats 2000 gallons of fuel, that single gallon will get me through at least 50-60 fillups.
I price compared it to DK before I bought it, to be sure the cost would work out, and it was a no brainer to me. For roughly $30 (the cost of a gallon of Diesel Treat), I can treat 2000 gallons of fuel. To treat the same amount of fuel with DK, it would cost over $130. $30 versus $130+...makes sense to me. It may not be the easiest to find and buy, but at the rate I use fuel, I'm only looking at having to buy the Diesel Treat once a year at the most. I've still got a good portion of the one gallon I opened left over from what I bought last summer.
