351M/400 Performance
Old Feb 9, 2002 | 04:49 PM
Mil1ion's Avatar
Mil1ion
Look what I came across this afternoon you guys.
It is quite interesting for performance oriented people.
http://www.amotion.com/fcm.html
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 10, 2002 | 04:34 PM
rea98d's Avatar
rea98d
Read those horsepower numbers! 480 HP & up on a 400! And to think some know-it-all with a 460 told me the only thing my 400 was good for was to plant flowers in the cylinder bores! 480 horsepower speaks for itself, I think
Old Feb 10, 2002 | 09:44 PM
GT40man's Avatar
GT40man
i have been trying to refine my planned build, and its not hard to get over 525hp estimated hp with a 400, and still have it streetable.
Old Feb 11, 2002 | 07:24 AM
shazam's Avatar
shazam
Ya Flat top pistons and some aussie heads with a good cam and your into the 400 to 500 H.P. Easy ......
Old Feb 11, 2002 | 03:41 PM
73Ranchero's Avatar
73Ranchero
How much are a set of higher compression pistons?? I have been kinda looking but all that I have seen cost sooo much.
Old Feb 19, 2002 | 07:57 PM
85bronco's Avatar
85bronco
I have been playing around with the numbers on a rebuild for a 351M and I will be getting around 600 hp but that is going to cost me a pretty penny. I will be using it as a race engine.
Old Feb 19, 2002 | 10:15 PM
xyfalcon500's Avatar
xyfalcon500
aren't 351C pistons the same as 400 pistons? i could be wrong...
Old Feb 20, 2002 | 08:30 AM
MrMotorsport's Avatar
MrMotorsport
aren't 351c pistons the same as 400 pistons? i could be wrong...
Yes and no. The 351C pistons are identical EXCEPT that they use a smaller piston pin (.912) than the 400 pistons (.975). If you want to use the 351C pistons in your 400, you must have your 400 rods bushed on the small end for the smaller 351C pins. It is a simple and cheap task any machine shop can accomplish for you. - Don
Old Feb 26, 2002 | 12:02 AM
weezel's Avatar
weezel
Ok guys...im 17, just a kid right? well i want to build up a 351 m or 400 i have a 351 in my truck now...i have 4 blocks sitting around, three are 351 and one is 400, where do i start and what do i do to get some serious and affordable horsepower with out digging myself a hole? email me or put on the message board, your ideas or expieriences please....thanks...josh
Old Feb 26, 2002 | 09:37 AM
Bill_Beyer's Avatar
Bill_Beyer
If you have 4 "M" blocks sitting around then I'd pick the one with the least taper, the most recent casting date (77 or later) and if possible one from the CF (Cleveland Foundry). All 4 blocks are basically identical so it makes absolutely no difference which one you start with.
While it's down at the machine shop being tanked and magnafluxed go spend some time reading this article on the 380+ Hot Rod magazine 400 buildup for about $2000: [link:home.earthlink.net/~tcrocker/400.html|H R 400 Build]
Old Feb 26, 2002 | 10:25 AM
weezel's Avatar
weezel
thanks for the article man, but instead of using reverse dome pistons could i use dome topped? or flats? would that be feasable? or insane?
and what is taper? and would it be possible to make this a stroker engine? or is that what the 400 crank is for...
Old Feb 26, 2002 | 12:11 PM
Bill_Beyer's Avatar
Bill_Beyer
>for...
Taper refers to the difference in diameter between the top and bottom of the cylinder. Cylinders wear more at the top than the bottom and more on the "outside & inside" than the "front & back". This is the result of increased combustion pressure at the top which dissapates as the piston travels downward and the rotation of the crankshaft/connecting rod assembly which turns reciprocating motion into circular motion. In order to correct the cylinders they have to be overbored. The less taper you have, the less you have to overbore the cylinders and the more metal you can keep in them.
Flat top pistons are available for the 400. Ohio Piston and Dynagear both carry them.
"Stroking" a 351M results in a 400. Although the 400 came first, the 351M is the exact same engine with a shorter stroke crank and unique pistons. Swapping the crank & pistons results in a 400 cid engine. It is possible to further stroke the 400 but you start getting into some major bux.
Old Mar 2, 2002 | 03:14 AM
GT40man's Avatar
GT40man
there is a lot of 335 engine building info out here on the web. check out project bronco, and get a good set of book about building these engines. these things will produce power, if you are careful.
Old Mar 3, 2002 | 06:41 PM
muddawg's Avatar
muddawg
No joke, the 335 series are a great base to build.I have one that is bone stock and i run it at 6000 rpm in my mudbog truck and its still hasnt scatered all over the place.
BOWTIES ARE FOR LIL BOYS!!!!!!!!!!!!
Old Mar 3, 2002 | 09:17 PM
GT40man's Avatar
GT40man
Mil1ion
Garage & Workshop
16
Jun 6, 2004 05:59 AM
Mil1ion
Mar 20, 2002 08:41 PM
Mil1ion
User Gallery & Picture Display
Mar 1, 2002 12:01 AM
Mil1ion
Feb 21, 2002 11:58 AM
Mil1ion
Garage & Workshop
Feb 19, 2002 11:19 PM
