tranny od problem
Old Mar 4, 2008 | 10:47 AM
new ford guy's Avatar
new ford guy
tranny od problem
hi my 1999 f-250 in stuck in overdrive and the shifter is flashing , what might be my problem?
Old Mar 4, 2008 | 11:10 AM
jim henderson's Avatar
jim henderson
The flashing shifter is the computer telling you that there is a problem and a code.
Get some one to read the code stored in the computer and post it here. Having the code helps eliminate a LOT of guesswork. Some tranny shops and autoparts stores will read codes for you. Tranny codes are less commonly read by auto parts stores. AAMCO will read codes for free but will give you a sales pitch.
You say stuck in OD. Does that mean from idle and whiel driving? Do the gears shift at all?
Good Luck, post the codes,
Jim Henderson
Old Mar 4, 2008 | 08:50 PM
new ford guy
ill have to get the exact codes i had it read by a tranny shop and nine codes came up two of them being the oxgen sensors, the guy said it could be a wire that liks everything together, when i put it in 1st it will roast the tires as well as in 2nd but when its in drive it feels like its pulling a house behind it lol so i start off in 2nd and just shift it manualy when i get to 40km/h
Old Mar 5, 2008 | 06:24 AM
projectSHO89's Avatar
projectSHO89
Check your O2 sensor wire harnesses to see if one of them has melted on the exhaust.
When they do, it blows the fuse that controls, among other things, the transmission solenoids.
Do get and post the exact codes.
Steve
goodconcenter
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jun 13, 2016 04:04 PM
Leatherneck007
Feb 1, 2015 02:06 PM
dm372
New Member Introductions
Feb 6, 2008 07:25 PM
robzombie
Mar 28, 2005 05:51 PM
blownbronco
1978 - 1996 Big Bronco
Jan 7, 2003 08:39 PM
