1978 - 1996 Big Bronco
can't find my problem
Old Jan 1, 2003 | 01:44 PM
blownbronco's Avatar
blownbronco
Old Jan 7, 2003 | 08:19 PM
found_on_roadside_dead's Avatar
I have a 93 eddie bauer 5.8l supercharged. My truck died and I can't figure out what the problem is. It spuddered out twice, and on the second time it wouldn't start. I have a spark, and my fuel pump is working well. It will crank but not turn over and start. I think it might be the injectors, but I'm not sure. If you have had this problem before let me know how you fixed it
thank you
Old Jan 7, 2003 | 08:39 PM
steve83's Avatar
steve83
For the engine to run, it needs:
Gasoline - check the schrader (tire) valve on the fuel rail to see if gas sprays out
Air - test the IAC according to the Haynes manual
Compression - use a screw-in compression tester
Spark - put a bolt in the distributor end of the coil, lay the bolt on the engine within 1/4" of some metal (but not touching), & observe while cranking
