Which air compressor do you own?
http://picasaweb.google.com/carl694/...98339654576642
This is obviously "oil-less"...
Horsepower can be determined by dividing wattage by 746.
23 amps @ 230 is a hell of a draw, are you sure that isn't inrush current?
Edit:
If you really want this compressor you might try finding a head for a 12 year old compressor, but that's up to you.
If you have some fabrication skills you could find another motor *and* head assembly and weld up something to work with the receiver you've just bought.
There's this.. This is the same compressor I'm using. Shouldn't be too hard to throw a pully on that electric motor to run this.
Not the greatest compressor in the world (aluminum body, just overall feels a bit on the cheap side) but you can't beat that price. I've not actually run it yet, so I can't tell you how the noise is.
It's a bit underpowered for your motor though, if it's really 23A at 230? My 4HP peaks at about 23A but is about 13A continuous. Make sure your lines are healthy for that monster
Nice score on a cheap pump head BTW....
The closest HF to me is 2 states away.
Would it be your advice to simply go out and purchase both a new compressor and motor and retrofit them to this receiver? Based on the prices I saw, it looks like I can get a decent 5 HP motor and good pump (about 13 cfms at 90 psi) for $550 all told. Is the payoff worth it considering I've got to deal with the hassle of retrofitting them for this tank? Or should I spend the same amount of money on a smaller unit with the same CFMs?
That motor can't be re-used since the motor end plate is that compressor housing. It'll get in the way of any belt drive, and the motor turns way too fast to direct-couple a regular compressor.
I'll try and get some pics of mine in a couple days, but for right now it's still covered.
Watch CL for an older used compressor with a small tank, maybe a 20-30gallon. Make sure it's a oil-lubed compressor, and you can either mount the whole compressor, motor and mount on your tank, or use your tank as a reciever inline to increase capacity.
And what are your fabrication skills???
From your photo I can't tell if you could press off the crank offset, cut back the mounting bosses and get a pulley to run true.
How does it mount to the receiver?
If you went with 'error's' head you'd need a double pulley that would turn it under 1200 rpm's, what's the speed of the motor you now have???
All this should be listed on the motor plate.
$550.....plus the time and parts (belts, pulleys, tensioners, tubing, brackets) to make it work and it will still be cobbled together. Are you in it for the challenge? Do you have the facilitys to accomplish it?
Me,........ I wouldn't waste my time.
This motor is very fast, 3450 RPMS. Sounds like it's total crap. It's funny, Ford_Six, because the guy that I bought this unit from said the pump - like yours - blew a rod.
I do not have much in the way of fabricating skills, Ardwrkntrk, so I think I might just try to make a bit of profit on this tank and put the money toward a new compressor. Sounds like I'm over my head on this one...But after buying this for $50, I might be able to sell it for $100.
I'm really itching to get a compressor, but I don't have $800 for a decent one. Maybe I'll start with a 30 gallon and go from there. I figure I can probably do some painting and sanding with a decent unit. It's not like I'm going to be using this thing every day. The reason I'm itchin' for one is that I changed the lower ball joints on my truck the other day and had a hell of a time getting the axle bolt off. I figure I could have taken off quite a few of the bolts on that job with an impact wrench and saved myself time/pain.
With a lot of things these days, I've found that older often is better made and can be rebuilt to it's original specs fairly easily, and will outlast the garage you put it in since you won't be running it 14 hours a day like the shop that had it before you.
While there are a lot of good brands old and new, I'm very fond of quincy because their compressor heads are VERY quiet.... instead of a blat-blat-blat at an incredible volume, it's more like a soft putt-putt-putt. With a quincy in a closet you could stand outside the closet while it's running and have a normal conversation - they're typically that quiet depending on the size of the unit.
There's also nothing wrong with "rolling your own" either to reduce costs and have a bit of fun if you're so inclined... an air compressor is nothing more than a tank, a compression head, two pulleys, a motor and a belt. I got a clean 60-gallon tank last year in trade for an old desk (which is so solid it's great for a workbench or welding table), and also in trade with another guy I got an old two-cylinder quincy head and pulley, which I rebuilt for about $55. I got off ebay for $7 plus $40 shipping (have to love no-reserve auctions) a 240V baldor motor new in the box - It's 8 HP I think. All I need to do is fabricate a base to mount the compressor head and the motor on, and fangle up a way to adjust tension on the pair of belts (double pulleys both ends).
Was it a bit of work? Yes. But I have myself a 25cfm rating @ 160psi... certainly more than I could ever use in my garage. And if you add up what I've paid (approximately) it's by far less than what I'd buy a new compressor for with those specifications.
Just some thoughts....
I found some guy with an old Quincy air compressor in the back of his truck and he gave it to me for free (he was only using it for extra weight in the winter)... The tank was rusted through, patched with Bondo, and was dated 1954. The old Dayton motor blew the long discontinued fuse the minnute I plugged it in, the rubber belt had zero flexability, or elasticity, and most of the plumbing was severly mangled... On the emergency release valve was a tag, indicating the compressor had been serviced, in 1975...
Not discouraged, I found an old motor from an NCR cash register I bought at an auction (of all things!!!), and used reinforced plastic tubing from an old air horn to replace the broken components of the plumbing system... It worked, and I only got rid of it because I ended up buying another Quincy (only $20!), that belonged to my friends dad...
Description: air compressor - vertical, 21 galon 115V,3.5 scfm@90psi, 8.8 scfm@40psi, hardley used. 1.5yr old like new.
includ 30' air hose. $125
