Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Which air compressor do you own?
Old Mar 30, 2008 | 08:47 AM
  #61
Help_Me!'s Avatar
Help_Me!
No, for some reason there's no mention of a model number on this unit anywhere. Seems like the only way to find out that type of info. is to call Quincy on Monday and give them the serial #. Maybe then I can learn all the specs, etc. and they should be able to tell me which type of oil I can use.
Old Mar 30, 2008 | 01:45 PM
  #62
cjben's Avatar
cjben
do you have any pics of the compressor? I could probably tell you what kind it is by looking at it.
Old Mar 30, 2008 | 01:54 PM
  #63
OverEngineer's Avatar
OverEngineer
Buy a used Industrial 3 phase Compressor
A used industrial compressors are pennies. You can buy them for the scrap price of the metal and for home use they'll usually kick everyone's **** down the street.
Take a PowerFlex inverter. Feed it 115 or 220 single phase and it will provide 230 three phase or (with a trick 460 vac)
On top of that, it can control the pressure to exactly where you would like it. No more loud noise hot compressor running at full speed. the inverter will match your consumption, keep the pressure dead on and save wear and tear
irsauctions.com is a great place to pick this stuff up
Old Mar 31, 2008 | 04:50 PM
  #64
durbancic's Avatar
durbancic
Im in the market for a compressor, what do you guys think of this one???
air compresser large tank
Sound like a fair asking price???
-dan
Old Mar 31, 2008 | 05:12 PM
  #65
Help_Me!'s Avatar
Help_Me!
Probably much more than the home mechanic needs, assuming his cfm quote is accurate. And keep in mind that that thing is going to weight at least 400 pounds or possibly a lot more based on that photo. If it's in good working order, that seems like a good price to me. But keep in mind how much space that hawg will eat up in your garage. Also curious why the tag says vertical compressor but it's obviously horizontal. If you buy it, make sure it's got a drain.
Old Mar 31, 2008 | 06:09 PM
  #66
Help_Me!'s Avatar
Help_Me!
Forgot to mention. Is this three-phase or a single-phase motor? You can only use single phase for home use unless you have three-phase installed. Can also buy a converter as mentioned above.
Old Mar 31, 2008 | 06:12 PM
  #67
durbancic's Avatar
durbancic
Im not sure, will email him to find out. Thanks
-dan
Old Mar 31, 2008 | 10:36 PM
  #68
durbancic's Avatar
durbancic
I emailed him this:
> I have a couple more questions for you. Is there a drain on the tank? Also, is this a single phase or a 3 phase? And why does the tag say vertical compressor, when it is running horizontal?
And this is how he responded:
Hello Yes there is a drain under the tank on the end by the air out lets, the shaft on the compressor is horizontal but the pistons run vertical, the motor says it runs on 115 or 230 I can tell you it has run on 230 as long as we have had it. we don't have three phase it would cost $1000 to bring it in to the property from the main street by my dads Thanks Bill
Does that mean that it requires 3 phase to run, and they are not using it because it costs too much to get it? Or they are running it without using 3 phase? Or it does not require 3 phase? This is all Greek to me...although I am slowly learning.
-dan
Old Mar 31, 2008 | 10:43 PM
  #69
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
No, if it can run at 115 or 230 it's single phase.
Look at the photo of the motor plate in the upper left corner.
Old Mar 31, 2008 | 10:48 PM
  #70
OverEngineer
Don't worry about the 220 volt wiring - Wherever you go... It should not be a big deal to install
Old Apr 1, 2008 | 12:40 AM
  #71
fixnair's Avatar
fixnair
Dan, I am very familiar with this model. It is called a vertical as opposed to a "horizontal" air compressor where the cylinder is configured to run parallell to the ground. This model is rated at a max psi of 100. It will do 150 but only at elevated temperatures (300°F) and reduced volumetric efficiency. Should be made to run @ 870 RPM with a 5 HP electric motor.
looking at what the seller says I would think it is now running with 220v single phase power.
Old Apr 1, 2008 | 05:30 AM
  #72
durbancic's Avatar
durbancic
Is that going to be a problem with it not running at 150PSI? That 13 CFM rating is probably at 150 I would be, right? Is this a fair price, I was thinking more around the lines of $275-300.
Old Apr 1, 2008 | 05:41 AM
  #73
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Many air tools are only rated @ 90-100 psi anyhow.
I think even you are shooting high for a fossil like this.
Old Apr 1, 2008 | 01:29 PM
  #74
durbancic's Avatar
durbancic
So would you recommend trying to get it for an even lower price, or just keep looking. I am in no huge rush to get one, would like to find one in the next 2 mos or so.
-dan
Old Apr 1, 2008 | 01:36 PM
  #75
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Doesn't look very cared for.
If the tank is rusty inside it's a hazard.
If you're in "no rush", I'd pass it by. He's asking way too much IMO.
