Offroad & 4x4
cross over steering
Old Mar 4, 2008 | 09:14 PM
Tre-E_Ford's Avatar
Tre-E_Ford
Hey thanks man, so no go on rotating the stock pitman arm, then. Either way thanks for the info, i'll definitely check in on that. I can do it all myself, we got a sweet machine shop and weld shop, this is just for future reference, but i'll eventually get to the point where i'll need to do it, 37's (that i'm planning on) aren't that big!
Could i get that minions entrance exam? frias88@yahoo.com
Old Mar 4, 2008 | 10:12 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
I still like Chronos idea better
Old Mar 4, 2008 | 11:09 PM
Tre-E_Ford's Avatar
Tre-E_Ford
Yeah i like the 4 stacked steering stabilizers!
Old Mar 4, 2008 | 11:16 PM
chrono4's Avatar
chrono4
and how all 3 parts of the system are bent...
Old Mar 5, 2008 | 06:16 AM
STGFordCrazy04's Avatar
STGFordCrazy04
Tre,
if you use the stock F250 dogleg pitman arm it will hit the crossmember under the engine.
check my gallery for more pics if you are interested.
Old Mar 5, 2008 | 06:20 AM
quadzjr's Avatar
quadzjr
just another Rockwell looser
Originally Posted by STGFordCrazy04
Tre,
needs more lift!
Old Mar 5, 2008 | 06:26 AM
STGFordCrazy04
Originally Posted by quadzjr
needs more lift!
It will clear 40s now. Im waiting to see you drop Fo-rod to tuck the 53s.
Old Mar 5, 2008 | 12:48 PM
Tre-E_Ford's Avatar
Tre-E_Ford
Tre,
Yeah i saw that, hmm....maybe new crossmember
Old Mar 5, 2008 | 01:16 PM
quadzjr's Avatar
quadzjr
nooooooooooo, more lift and a drop pitman arm!!!!
Old Mar 5, 2008 | 04:11 PM
Tre-E_Ford's Avatar
Tre-E_Ford
We'll see... you haven't convinced me yet
Old Mar 5, 2008 | 04:25 PM
STGFordCrazy04
you seriously need a F150 style pitman arm to make it work. All the lift in the world wont move the crossmember and its pointless to cut it out so you can save $70 on a new pitman.
Old Mar 5, 2008 | 04:31 PM
Tre-E_Ford's Avatar
Tre-E_Ford
Got it boss, i'll do that. I just meant that a new crossmember would be cool too. Just another excuse to work on my truck.
Old Mar 5, 2008 | 06:00 PM
  #28
quadzjr's Avatar
quadzjr
its not going to clear them rediculously......it will semi-tuck them...
Old Mar 5, 2008 | 06:02 PM
  #29
quadzjr's Avatar
quadzjr
if you have more lift you can use a drop pitman arm that will clear the crossmember, b/c right now kris's hit his drag link
correct me if im wrong kris
Old Mar 5, 2008 | 06:11 PM
  #30
STGFordCrazy04
more lift (8"+) might allow me to use the driver side steering arm and have highsteer like originally planned. I bought a 4" drop pitman arm for my 4" suspension lift but I probably shouldve bought a factory height arm. No amount of lift will move the crossmember the F150 style arm gets under it.
Im not 100% convinced that even with 8"+ lift I could have highsteer. The tie rod gets in the way of the drag link with my arms.
