Code Alarm CA-530 wiring
Old Mar 3, 2008 | 07:27 PM
bcrab's Avatar
bcrab
Just bought a CA-530 remote starter with the XK04 programable bypass module. I bought it local for $115 because the store was going out of business. But I need to get a diagram for the truck and where to find the wires in the truck I'll need for install. If anyone has some ideas I would really appreciat it.
2005 FX4 scab
Old Mar 3, 2008 | 08:00 PM
Ford Fx4's Avatar
Ford Fx4
<table id="ppp" style="margin-top: 5px;" cellpadding="2" cellspacing="0" width="100%"><tbody><tr><td style="font-weight: bold;">2005 F-150
PASSIVE ANTI-THEFT
</td> <td> YES</td> <td> TRANSPONDER </td> <td align="center"> SEE NOTES </td></tr> <tr> <td style="font-weight: bold;"> 12 VOLTS</td> <td> Green/purple</td> <td> Ignition switch harness </td> <td align="center"> + </td></tr> <tr> <td style="font-weight: bold;"> IGNITION</td> <td> dk.Blue/lt.green</td> <td> Ignition switch harness </td> <td align="center"> + </td></tr> <tr> <td style="font-weight: bold;"> ACCESSORY</td> <td> Black/lt.green</td> <td> Ignition switch harness </td> <td align="center"> + </td></tr> <tr> <td style="font-weight: bold;"> STARTER</td> <td> Red/lt. blue
</td> <td> Ignition switch harness </td> <td align="center"> + </td></tr> <tr> <td style="font-weight: bold;"> KEY SENSE</td> <td> Black/pink</td> <td> Ignition switch harness </td> <td align="center"> + </td></tr> <tr> <td style="font-weight: bold;"> TACH SIGNAL</td> <td> Opposite of Red/green</td> <td> At any coil on engine </td> <td align="center"> AC </td></tr> <tr> <td style="font-weight: bold;"> FUEL INJECTOR</td> <td> Opposite of Red</td> <td> At any injector on engine </td> <td align="center"> AC </td></tr> <tr> <td style="font-weight: bold;"> LOCK</td> <td> Pink/yellow</td> <td> Low in driver's kickpanel </td> <td align="center"> - </td></tr> <tr> <td style="font-weight: bold;"> UNLOCK</td> <td> Pink/lt.green</td> <td> Low in driver's kickpanel </td> <td align="center"> - </td></tr> <tr> <td style="font-weight: bold;"> DOORPIN</td> <td> Black/Yellow & Black/Pink</td> <td> Driver's kick panel </td> <td align="center"> - </td></tr> <tr> <td colspan="4"> <t> <t> </t></t><table class="NotesTable" cellspadding="0" cellspacing="0"><tbody><tr> <td valign="top"> </td> <td width="1">
</td> <td style="font-size: 10pt;" valign="top" width="100%">Doorpins in this vehicle are independent, WITHOUT factory keyless Drivers door is Black/Yellow, Passenger Door is Black/Pink,found in gray plug in drivers kick panel, With factory keyless Drivers door is Black/Yellow, Passenger door is Black/Pink, Left rear door is Black/Lt.Blue, Right Rear Door is black/White , All wires are found at B.C.M. behind rear driver's side panel.</td></tr></tbody></table></td></tr> <tr> <td style="font-weight: bold;"> BRAKESWITCH</td> <td> lt.Green</td> <td> At switch above brake pedal </td> <td align="center"> + </td></tr> <tr> <td style="font-weight: bold;"> PARKLIGHTS</td> <td> Brown</td> <td> At light switch harness </td> <td align="center"> + </td></tr> <tr> <td style="font-weight: bold;"> HAND BRAKE</td> <td> Lt.green/red</td> <td> At switch on handbrake lever </td> <td align="center"> - </td></tr> <tr> <td style="font-weight: bold;"> HORN</td> <td> Dk.blue</td> <td> At steering column </td> <td align="center"> - </td></tr> <tr> <td style="font-weight: bold;"> HEADLIGHTS</td> <td> Red/yellow</td> <td> At light switch harness </td> <td align="center"> + </td></tr> <tr> <td style="font-weight: bold;"> VSS WIRE</td> <td> Gray/black</td> <td> In radio harness behind radio </td> <td align="center"> </td></tr> <tr> <td style="font-weight: bold;"> TRANSPONDER IGNITION</td> <td> Red/lt.green</td> <td> In 4-pin plug on steering column </td> <td align="center"> + </td></tr> <tr> <td style="font-weight: bold;"> TRANSPONDER DATA 1</td> <td> Gray/orange</td> <td> In 4-pin plug on steering column </td> <td align="center"> DATA </td></tr> <tr> <td style="font-weight: bold;"> TRANSPONDER DATA 2</td> <td> White/lt.green</td> <td> In 4-pin plug on steering column </td> <td align="center"> DATA </td></tr> <tr> <td style="font-weight: bold;"> TRANSPONDER GROUND</td> <td> Black/lt.blue</td> <td> In 4-pin plug on steering column </td> <td align="center">
Old Mar 3, 2008 | 11:08 PM
black04lariat's Avatar
black04lariat
When you go to hookup your door trigger wire you may find it easier to just use the "dome supervision" wire instead of isolating the individual door pins. Just make sure you have the polarity correct on the brain.
Dome Supervision : black/lt. blue +, Driver Kick Panel, gray plug, pin 6
I think I recall getting mine under the door sill panel.
And be sure to test all your wires before you hook 'em up.
Old Mar 3, 2008 | 11:13 PM
black04lariat
And for future reference. This site has a lot of great wiring/12volt info.
http://www.the12volt.com/installbay/vehicles.html
Old Mar 4, 2008 | 01:23 PM
bcrab's Avatar
bcrab
Thanks...gonna try to install this weekend.
Offshore530
Jan 24, 2017 08:57 AM
kawasakiklx1
Jan 18, 2017 03:15 PM
knightofmyth530
May 11, 2016 04:57 PM
ErrorS
1978 - 1996 Big Bronco
Apr 16, 2012 10:04 AM
Ford Fx4
2004 - 2008 F150
Nov 18, 2007 08:51 PM
