Sponsored by: Real Truck
F-350 Steering problems
Old Mar 3, 2008 | 03:34 PM
tader's Avatar
tader
I need some help. I have a 1997 Ford F-350 with a 7.3 LTR diesil. I am having steering problems. What it is doing is surgeing kinda like it is trying to correct its self. I already have had to put a new steering box on it. Today I replaced the power steering pump to see if that is the problem. No luck with that. Anyone have any suggestions?
Old Mar 3, 2008 | 05:07 PM
redford's Avatar
redford
FTE Leadership Emeritus
Is this a 4 wheel drive truck?
Could a hub or bearing be dragging every now and again, causing a "pull" to one side?
Also, it could be the tires. Try putting the front tires on the back axle, see what the truck does after that.
Old Mar 3, 2008 | 07:40 PM
tader's Avatar
tader
yes it is 4 wheel drive. It will do it when it is sitting still.
Old Mar 4, 2008 | 04:52 PM
tader's Avatar
tader
could this be air getting into the line through a fitting?
Old Mar 7, 2008 | 10:19 AM
tader's Avatar
tader
I have some new information. I checked at a local parts house about anothor steering box because this is what I suspect is the problem. They said their is two different boxes for this truck depending on the production date. The difference is the gear ratio and no visual difference. When I contacted the dealer ( where the box on the truck came from ) they said that their is two boxes to choose from. A two and four bolt and they gave me the four. Anyone know how to distinguish between the two bolt and four? Whitch place knows what they are talking about?
northernsuperduty
Dec 11, 2014 10:06 PM
Rick2006
Mar 28, 2012 01:24 PM
MikeMcq
Jun 13, 2011 07:12 PM
bansheeduner
Jan 9, 2008 10:42 AM
Whitey078
Feb 13, 2004 03:32 PM
