351c's transmiision??
Old Mar 19, 2002 | 09:45 AM
dereklovejoy's Avatar
dereklovejoy
I have a 79 bronco with a 351`c motor in it. its automatic trans has ***** the bed. i need another one. anyone know what model number or whatever transmission i need for this. thanks.
Old Mar 19, 2002 | 12:08 PM
cardude's Avatar
cardude
If it is a cleveland, it has the same bellhousing as other small block fords. A c-4 will do. If it is a 351 M (which is sometimes mistaken for a cleveland) it has a big block bell pattern. A c-6 will have to do.
count the tranny pan bolts to see what tranny you have (assuming it is either a c4 or c6). A c4 will have 11 bolts, a c6 will have 17 (i think)
Old Mar 19, 2002 | 04:46 PM
Franklin2's Avatar
Franklin2
Old Mar 22, 2002 | 06:53 AM
bbtkd's Avatar
bbtkd
[updated:LAST EDITED ON 22-Mar-02 AT 07:58 AM (EST)]>I have a 79 bronco with a 351`c motor in it. its automatic
>thanks.
A C4 or FMX would work, but I'd suggest a C6 if you are going to hot dog it at all. A B&M (or competitor) shift kit will crispen up the shifts nicely (though I would not suggest doing that with a tired used transmission). The shifts can be crisp enough to shear off an input shaft - been there, done that...
BTW - make sure that whatever transmission you get has the small block bolt pattern (289, 302, 351C, 351W). The 351M, 400, 429, 460, 428, 390, or 352 have a big-block bolt pattern and won't work for you. Come to think of it - make sure that if you use a different transmission than you have now, that it will work with your transfer case - may be some 'special' considerations such as length of the case...
Ripcity
Oct 18, 2013 07:24 PM
YoungMT Hick
15
Oct 21, 2007 01:48 PM
blatherskite
Jun 3, 2004 10:40 PM
f100351c
Nov 7, 2002 01:52 PM
