351C/400 difference
Old Sep 2, 2007 | 11:16 PM
YoungMT Hick's Avatar
YoungMT Hick
351C/400 difference
ok looked for some articles but i need to know if the only way i can determine if its a 351c/351m to the 400 is to measure the stroke 3.5 vs 4.00"
Old Sep 3, 2007 | 10:25 AM
grclark351's Avatar
grclark351
are you not sure if you have a Cleveland or a 351M/400? the 351M and 400 are visually identical but the Cleveland is different. is this engine the original to the vehicle? US trucks never came with a Cleveland, only the M/400. if the engine is believed to be original, what is the 5th digit of the VIN? if not we can go from there.
Old Sep 3, 2007 | 02:09 PM
YoungMT Hick
f26sr is the first five it is believed to be a cleveland because of the number of bolts in the valve covers. a cleveland has 8 and the m has six? let me know this truck might be rare
Old Sep 3, 2007 | 07:38 PM
grclark351's Avatar
grclark351
the "F" in script in front of the VIN doesn't count, that's the first 4, what's the next digit? is the engine believed to be original to the body? Cleveland and 351M/400's use the same valve covers, so same bolt count. you can't tell them apart that way.
Old Oct 16, 2007 | 10:41 PM
jskull351's Avatar
jskull351
f26sr means f26=f250 4X4,the sr =V8 400 6.6L with a 2BBL carb manufactured 77 thru 79
Old Oct 19, 2007 | 09:41 PM
10MPG's Avatar
10MPG
Cleveland uses a small block bell pattern,the 351m/400 uses the 429/460 style bell.
Old Oct 19, 2007 | 11:41 PM
ihateminimumwage's Avatar
ihateminimumwage
Originally Posted by YoungMT Hick
...because of the number of bolts in the valve covers. a cleveland has 8 and the m has six?
Other way around. 351m/400 has 8 valve cover bolts.
Old Oct 20, 2007 | 12:16 AM
grclark351's Avatar
grclark351
the Cleveland and the 351M/400 use the same valve covers.
Old Oct 20, 2007 | 01:29 AM
ihateminimumwage
Sorry about that, you're right. Haven't been on here a while... Starting to forget things...
Difference between a 351M and a 400, measure the stroke, like mentioned in OP.
Difference in 351C & 351m, search. I did and one of the first to pop up was this:
https://www.ford-trucks.com/forums/6...ight=cleveland
Old Oct 20, 2007 | 02:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It's a 400 by the VIN.
F26 = F250 4WD
S = 400 2V
R = San Jose CA Assembly Plant
351C/351M/400 all have 8 valve cover bolts.
Old Oct 20, 2007 | 02:20 AM
NumberDummy
The F does count. What he posted is correct.
Old Oct 20, 2007 | 11:02 AM
grclark351's Avatar
grclark351
ok, the truck vin might be different. i was going by the Ranghero/car vin digit placement, where the engine would be the 5th digit. "R" didn't ring any bells. thanks.
Old Oct 20, 2007 | 02:07 PM
NumberDummy
The Ford trucks 11 digit VIN's from 1957 through 1980 began with an F in most cases. The cars 11 digit VIN's began with a number denoting the year thru 1979.
Samples from 1965: Cars: 5RO2C123456 / Trucks: F10DR639123
Cars went to 17 digit VIN's in 1980, trucks in 1981.
Old Oct 20, 2007 | 06:18 PM
mustang81's Avatar
mustang81
mesure the crank stroke or look for a ridge on the first conterweight.351m don't have it.
400 does.351m/400 motors have a taller deck height by 1".
Old Oct 20, 2007 | 06:21 PM
grclark351's Avatar
grclark351
http://www.tmeyerinc.com/Fordvisualcompare.html
