Starter Leaking???
Old Mar 3, 2008 | 02:10 PM
ldfry001's Avatar
ldfry001
Starter Leaking???
Are the starters on a 1999 f250 in oil? it looks to me like the started is leaking. i dont really see any oil anywhere else.
thanks
Old Mar 3, 2008 | 02:40 PM
MTDewX's Avatar
MTDewX
that is weird, cause if you change your starter (which I just did) oil coming out is not an issue. all you have to worry about the power cables and 3 or two bolts.
Old Mar 3, 2008 | 03:26 PM
clintbonnie's Avatar
clintbonnie
It is probably coming from your pedestal up above the starter. The "O" rings are probably leaking.. It is pretty common to have a leak here. Double check your engine valley for oil however..(could be your hpop if you have oil in the valley) . My petestal is leaking a littel but not enough to change the o rings yet.
Old Mar 3, 2008 | 03:48 PM
PaysonPSD's Avatar
PaysonPSD
Check at the bottom end of the dipstick tube. It is behind the starter. It looks like this:
Old Mar 3, 2008 | 05:01 PM
SVLERF250PWRSTRKE's Avatar
SVLERF250PWRSTRKE
Oh no your losing precious ford starter fluid. That stuff is about 50 bucks a quart!, Sorry I had too.. I'm sure its oil from your pedestal
Old Mar 3, 2008 | 05:42 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I'm sorry too, I love this post, and only wish I had beat you to it. That is a great photo in the post above, but how in the Hell did you do that?
Old Mar 3, 2008 | 05:46 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Little invention called a CAMERA.
Sorry, I had to.
Old Mar 3, 2008 | 06:01 PM
Markadeck's Avatar
Markadeck
Sorry, I had to.
Apology accepted, it's just that I did not know you could get that good of a view of it, course I have a 2wd and do not have the ground clearance most every other member here has. But I do get much better mpg.
Old Mar 3, 2008 | 06:30 PM
PaysonPSD's Avatar
PaysonPSD
it's just that I did not know you could get that good of a view of it.
Picture taken with starter removed .
Old Mar 3, 2008 | 06:34 PM
Markadeck's Avatar
Markadeck
Okay, now that sounds a little easier, but both times I've changed my starter I've been occupied doing just that. But i'ts still a good photo, why you did it, let alone saved it is kind of a mystery, but to each his own.
Old Mar 3, 2008 | 06:38 PM
clux's Avatar
clux
Some people are turned on by feet, others by legs.................
for PaysonPSD, it's dipsticks.
Old Mar 3, 2008 | 07:04 PM
PaysonPSD's Avatar
PaysonPSD
Last November I thought I had an oil leak from the flange but it turned out to be the dipstick tube o-ring. I have actually helped a few people fix an oil leak by posting that pic. If you have a 500 Gigabit back-up hard drive you tend to save a lot of crap . Besides I never said I took the picture. I found it posted here on FTE. The pic was posted by Andy aka FatDiesel.
https://www.ford-trucks.com/forums/6...with-pics.html
Old Mar 3, 2008 | 08:04 PM
F350-6's Avatar
F350-6
It looks like this:
No it doesn't. That's what it looked like when it was new. Now it has about 1" of gunk all over it.
(The OP disappeared and everyone else is off topic, so I'm just keeping up my end of the conversation)
Old Mar 3, 2008 | 08:17 PM
swaybar's Avatar
swaybar
are you sure its (oil)?
just today i had a new (ground) leak and it was coming off the starter. but the puddle was fuel. above the starter, on the back of the engine is a fuel return line. you can follow it from the fuel filter housing. anyway it somehow was 1/8 of a turn loose. tightend it, and no more leak.
Old Mar 4, 2008 | 12:06 AM
PaysonPSD's Avatar
PaysonPSD
Well let's just say "It should look like this". And no tellin' what Andy's looked like before he cleaned it up for the picture.
firegod75
Feb 3, 2015 02:29 PM
rsh
Apr 26, 2010 08:33 PM
firefighter1416
1997 - 2003 F150
Feb 5, 2009 05:24 PM
g tinsley
Oct 31, 2007 02:11 PM
RLawns
Oct 24, 2006 07:14 PM
