Engine problem???
Old Mar 3, 2008 | 11:10 AM
apbtpetey's Avatar
apbtpetey
Engine problem???
Okay so I am driving to work this morning going between 55-60mph and all of a sudden I hear a pop (not very loud, but it was a pop sound) come from the truck and then it just died. I coast down the side of the road till it stops and try to start it. It will turn over, but doesn't start. There is no sounds of anything loose. Any clues as to what I might be looking at? I have a friend who will take a look at it for me, but I figured I'd ask for opinions on here as well.
truck is 1977 f-250 with the 300 in and 4-speed on the floor and 4 wheel drive.
Old Mar 3, 2008 | 11:40 AM
S.A.FORD's Avatar
S.A.FORD
Check and see if you have spark. Is it a DS-2 system if so ive had that happen when the inginition box went out.
HHW
Old Mar 3, 2008 | 11:45 AM
Silver Streak's Avatar
Silver Streak
Check to see if the distributor is turning. The plastic timing gears might have left the building.
Old Mar 3, 2008 | 12:08 PM
AbandonedBronco's Avatar
AbandonedBronco
I didn't think a '77 300 had plastic timing gears.
I'd probably check the ignition module too.
Old Mar 3, 2008 | 12:34 PM
Silver Streak
I think they started using them right around that time, but it might have been later.
Old Mar 3, 2008 | 02:07 PM
apbtpetey's Avatar
apbtpetey
Thanks for the fast replies. I'll mention the info to my friend. Not sure if it makes a difference with the timing gears, but mine truck is a 1977.5 so it's not a highboy. I am so use to just calling it a 77 and forget that it is really a 77.5
Old Mar 3, 2008 | 04:34 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Could be a module or a coil.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Mar 3, 2008 | 08:27 PM
apbtpetey's Avatar
apbtpetey
Okay the problem was a bad igintion module. Thanks for all the input
Old Mar 4, 2008 | 01:43 PM
Silver Streak
That's good. Could have been much worse. The bang is a little puzzling.
Old Mar 4, 2008 | 06:34 PM
jfarcas's Avatar
jfarcas
The bang was probably a decently strong misfire after that module took a crap on ya.
