rim backspacing/offset question
Old Mar 3, 2008 | 09:03 AM
crestfallinman's Avatar
crestfallinman
ok im gouing to get the cragar soft 8 steel wheels
on jegs it says the rear spacing is 4 inches
on a different site it says the offset is -13
will the ones on jegs work? they are cheaper
and i have a 2wd shorebed reg cab
Old Mar 3, 2008 | 02:03 PM
crestfallinman
does anyone know about this?
Old Mar 3, 2008 | 03:26 PM
pacrewchief's Avatar
pacrewchief
The wheel with the 4 inch backspace will work. As far as that ( -13 ) I have no idea what that means.
Old Mar 4, 2008 | 08:07 AM
hojolabo's Avatar
hojolabo
Sounds to me that the -13s are wider rims for racing slicks or some other wide tire, therefore more $$$. Try measuring your existing backspace. I put 16x10" Eagle alloy's on my 92" with 33s and I get a slight tire rub on a tight turn. I just use a larger turn radius. No big deal, how often do you have to lock the wheel on a turn anyhow.
Old Mar 4, 2008 | 11:17 AM
crestfallinman
lol yeah
thanks so much for thelp
Dodge-My-Cummins
Jan 19, 2015 07:53 AM
Louie3
Exhaust Systems
Oct 5, 2008 02:20 PM
JRFX4
Mar 1, 2006 01:54 PM
Dalamatition
Apr 13, 2004 08:14 AM
pdsq89f150
1997 - 2003 F150
May 29, 2003 12:06 AM
