Cheater Throttle Cable?
Old Mar 7, 2008 | 05:33 PM
79f100six's Avatar
79f100six
I was looking at an ebay auction and the truck has a np435 and the guy says "I got a cheater throttle cable installed on the shifter so when your out rockcrawling something steep you can work the gas with your finger and the clutch and brake with your feet.... this comes in very handy and beats trying to use 2 feet on three pedels." I was wondering if anyone has done this and how could it be done. This idea sounds really good for the new truck that i am getting the also has a stick.
Old Mar 7, 2008 | 05:42 PM
Mil1ion's Avatar
Mil1ion
Probably just a choke cable retro-fitted on the accelerator.
Concrete trucks have this feature.
Old Mar 7, 2008 | 06:32 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Yeah alot of dump trucks, OTR and short haul trucks use a PTO throttle. Like Mi1lion said it is basically a choke cable, but you would need to figure out a way for the cable to not interfere while you use the pedal.
Old Mar 7, 2008 | 06:45 PM
cykoticford's Avatar
cykoticford
my neighbors old flat bed had one on the shifter it was connected to the carb with a spring so it wouldn't bind with the pedal.. don't know if it was factory
Old Mar 7, 2008 | 07:27 PM
RCrawler's Avatar
RCrawler
You can get a throttle cable or PTO cable with a turn and lock feature at any truck parts house. It does come in handy on the trail for driving as well as raising the RPM's for winching, charging or building air.
Jason
Old Mar 7, 2008 | 10:13 PM
OldMetal's Avatar
OldMetal
seen lots of them, fire truck use them. You simply turn the **** to the desired rpm and push a release botton to drop back to idle.
