door panel removal
Old May 16, 2008 | 08:07 AM
tom41's Avatar
tom41
door panel removal
How do I go about removing the door panel (front passenger ) on my 99 f350? need to remove so I can maybe knock out a large dent..thanks
Tom
Old May 16, 2008 | 08:12 AM
Kwikkordead's Avatar
Kwikkordead
Tom
There is a couple of anchor screws to remove. One of them is behind the red lens in the bottom of the door panel. I forget where the other one is, but once they are removed, lift up on the entire panel and it comes off.
Unplug window switches and speakers as needed.
A 60 second job, basically.
Old May 16, 2008 | 08:23 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Just the other day a great link was posted for me regarding this. Do a search back to 5/12 on this same subject and you will find the link. Photos and all.
Old May 16, 2008 | 08:27 AM
Markadeck's Avatar
Markadeck
I found it for you
Door panel removal
Old May 16, 2008 | 08:42 AM
DaveWilliams's Avatar
DaveWilliams
Thumbs up Great info..
I am glad there are not those little push pin type fasteners. They make pulling panels difficult, and they never hold right when you put them back on...Thanks for the link to the pics...
Old May 16, 2008 | 09:24 AM
tom41's Avatar
tom41
thanks Mark & Dan for your quick replies. A very big THANKS for the pics!!
Tom
Old May 16, 2008 | 12:21 PM
Markadeck's Avatar
Markadeck
Y'all can thank and rep Chris, F350-6 for the great link, I was just the middleman. But it is kinda neat, ain't it?
Old May 16, 2008 | 03:17 PM
Layson's Avatar
Layson
One thing you can try on the dents is this....
get a couple cans of the computer duster cleaner cans. Then spray the air real close to the truck so it freezes on the truck on the dent. Then get a heat gun and pass it over the frozen portion and the dent and it just may pop out on its own... I have seen this work on some pretty bad dents before...
good luck,
Old May 16, 2008 | 03:34 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
good luck,
that is AWESOME!!! I'm going to try that on my girl's truck - one of her horses decided to bump her door one day... oops
Is this similar to what they do for "paintless dent repair"?
Old May 16, 2008 | 03:38 PM
Layson's Avatar
Layson
I have no idea... but it is like magic... you just sit back and the dents pop out.
It won't work on everything... but it does work!
Markadeck's Avatar
Markadeck
[quote=papadelogan;6161563]that is AWESOME!!! I'm going to try that on my girl's truck - one of her horses decided to bump her door one day... oops
Is this similar to what they do for "paintless dent repair"?[/quo
I'd like to know the results of this trick, and no it's not similiar. They use special tools that will amaze the layman.
Old May 16, 2008 | 04:00 PM
Markadeck's Avatar
Markadeck
I wonder if liquid nitrogen would do the same thing? It would also have to be a real heat gun because a 1500 watt hairdryer would not get hot enough, right?
Old May 16, 2008 | 04:13 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
How about a co2 fire extinguisher and a cutting torch? I know that would be cold enough and the torch would be hot enough.
Old May 16, 2008 | 04:17 PM
Layson's Avatar
Layson
Yeah you could melt it back into shape...LOL..
It is just a standard heat gun. We didn't use a hairdryer... I bet some of those may work..LOL..
Old May 16, 2008 | 04:26 PM
Markadeck's Avatar
Markadeck
Yeah but the torch would destroy the paint on my nearly pristine Vdub. My truck is dent free.
