need an engine decoder
Old Mar 2, 2008 | 07:47 PM
fdude64's Avatar
fdude64
picked up my spare engine yesterday and wanted to make sure what i got. the PO told me it is a 460 the number on the block is
d1ve-a2b
the numbers on the heads are
d3ve-a2a
could someone tell me where i can decode this?
Old Mar 2, 2008 | 08:10 PM
hotrodmerc's Avatar
hotrodmerc
1971 Block
1973 Heads
Old Mar 2, 2008 | 08:20 PM
fdude64's Avatar
fdude64
so my guess would be it has been rebuilt? or at the least had heads replaced.
Old Mar 2, 2008 | 08:21 PM
fdude64's Avatar
fdude64
also is it really a 460?
Old Mar 3, 2008 | 01:25 AM
Handegard's Avatar
Handegard
Thats basically a revision number. Some parts get changed frequently, others go years without being updated. My '85s original motor is a D9 ('79) casting number.
It's likely that D1 and D3 were just the most recent revisions when that motor was built...
It can only be either a 370/429/460, someone might chime in with a way to tell. I don't know how to tell beisdes bore and stroke...
Old Mar 3, 2008 | 02:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D1VE-6015-AB is the bare block casting number for a 429/460 raw (unfinished) block used from 1971 thru midyear 1979.
Midyear 1979 and later 460's: D9TE-6015-AB
Casting numbers cannot be translated to actual Ford part numbers.
Your D1VE block could be a 429, it could be a 460.
Measure the stroke: A 429 is 3.69" / A 460 is 3.85"
The same cylinder heads (actual Ford part number: D4VZ-6049-C) were used on both 429/460's 1973/74 (460's thru 1978 on passenger cars / Thru 4/1/1985 on trucks).
Old Mar 3, 2008 | 03:28 AM
fdude64's Avatar
fdude64
well i dont think i am going to tear it down far enough to measure the stroke. just freshen it up a little and drop it in
Old Mar 3, 2008 | 03:37 AM
NumberDummy
All you need to do to measure the stroke is remove one spark plug, drivers side front. Insert a wooden dowel with the piston all the way down. Measure...that's it.
If the engine came from a Lincoln Town Car or Continental Mark III, IV or V (1968/78), it's a 460. Lincoln's didn't use 429's.
Old Mar 3, 2008 | 03:44 AM
fdude64's Avatar
fdude64
ok thanks for the info. i dont know what it came out of PO just said it was a 460
highoctane74
Apr 22, 2009 01:24 PM
specialkid66
Sep 24, 2007 11:52 PM
redneckchuck
New Member Introductions
Feb 11, 2007 07:14 AM
Brian460
Jul 14, 2002 11:39 AM
1ole4d
Dec 9, 2001 01:43 PM
