Some people report noise from the front end; the easiest and most definitive check is to jack up the vehicle (one side at a time is fine) and try to wiggle the wheel by pushing and pulling on the top or the bottom, any movement and/or clunking noise is usually an indication that the ball joints are worn out.
Easy test if they are REALLY bad (Like mine were) Jack the truck up until the front wheels are about 3 inches off the ground, then set it on jack stands. Grab a piece of 2x4 lumber, stick one end under a wheel, and lift the board up then down several times. (You don't have to put a lot of effort into this, you are not trying to pick up the front of the truck, just wiggle the wheel) Watch the wheel / suspention from the front end of the truck while doing this. If the wheel goes up and down, with a clunking noise, but the suspention is not moving, it is a pretty safe bet you have a ball joint job in your near future.
how much would someone be looking at to replace all 4? what are the best one to bye? on my 97 powerstroke I bought them from napa the best they had and they wre only about 50.00$ each (200.00$).
If they are like my 97, alot of patience, and in my case all day. I have a friend that is a mechanic and he did the work. He could have done it faster but it was in my drive way.
I bought my Moog ball joints at 1AAuto.com for a couple bucks more than Rockauto.com. The only real difficult part is working on an icy driveway in winter. I had a local mechanic friend agree to do the labor for under $600 + the $200 that I spent on the parts online. That was a lot better than the dealers quote of $1800. He did recommend looking at the ujoints, brakes, etc. since all the parts are already off. It'll save on labor in the long run.
Just three days ago, I was cornered by circumstances into paying a shop to do my right side ball joints. They are at least a reputable shop, but there was a parts markup and labor I had wanted to avoid, but the job had to be done. Nuff said about that.
Price...
Both ball joints (Moog greasable) and adjustable camber bushing, plus labor & alignment, totaled $405. Of this total, labor was $175 and the alignment was $59.
They did a good job, but I still wish I could have done the job myself.
$405 for parts and labor dont sound too bad. I have a 1 year warranty on my alignments so I can save there. These guys here will probably quote me 400 just for labor. Thanks for the input. I'm looking at the MOOG ball joints right now.
Every quote I got around here was for $1500+. I did it myself but it took a few days, a couple of friends (mostly drinking my beer and telling me what I should be doing), and a very big press that still wasn't big enough. If you don't have access to a press it will still be a lot cheaper to pull the knuckles yourself and take them and your parts to a machine shop. Good luck. This isn't a hard job but it is a pain in the butt.
