Pulled out by a Chebby
Old Mar 16, 2008 | 01:20 PM
FrontRangeF150's Avatar
FrontRangeF150
Did you ever resolve this issue??? I have the same problem with my passenger side bearing, once everything is removed the rotor will not come off. The bearing grenaded on me, whats the best way to remove the rotor without tearing things up???
Old Mar 16, 2008 | 05:26 PM
19FORD93's Avatar
19FORD93
I haven't resolved this issue yet. Didnt have much time to work on the truck so i had to throw everything back together. I think things got so hot from the play that the seal melted everything together. I'm going to have to buy a puller or rent one from the auto parts store to get the hub/rotor off.
Old Mar 16, 2008 | 11:00 PM
FrontRangeF150
I ended up deciding to buy a new rotor and hub assembly since the condition of the bearings where so bad. I used a hammer and beat the crap out of the back side of the rotor to dislodge it from the spindle. I would suggest not trying to turn the rotor with your finger in one of the heat vents around the outside, if it spins and catches your finger between the rotor and the caliper mount it hurts really bad. My bearings welded themselves to the rotor and the whole thing needed to be replaced. I ordered the rotor and hub assembly off of Jeff's Bronco Graveyard for alot less than the dealer charges. My spindle is in good shape so I didn't have to worry about that. It took a while to dislodge the rotor assembly but it worked its way out.
SSSimon
Australia Chapter
19
Jan 1, 2014 01:23 AM
lundman
6.7L Power Stroke Diesel
Feb 18, 2013 10:15 AM
BroncoPimp94
Feb 9, 2010 06:45 PM
Old93junk
Offroad & 4x4
Apr 29, 2009 07:06 PM
jsleona
Jan 14, 2007 10:13 PM
