Sponsored by: Real Truck
Overdrive light question
Old Mar 2, 2008 | 12:02 PM
oct7brian's Avatar
oct7brian
Recently bought a 00 F250 w/ a Power Stroke. Yesterday I was going to make a heavy haul and went to turn the OD off and it had no effect the transmission shifted the same and the light did not light up. Is there a fuse that controls the overdrive that could be blown. It not a huge deal since the transmission shifts smoothly anyway just curious. Also could this be disabled since the truck has a 140hp chip?
Old Mar 2, 2008 | 12:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The wires to the button and light often break where they enter the shifter handle inside the steering column. Remove the plastic cover and check the wires where they enter the shifter. They are probably broken or worn through. You can repair them or replace the shifter for about $50.
Old Mar 2, 2008 | 07:03 PM
oct7brian's Avatar
oct7brian
I assume the cover you are talking about is the one around the column right behind the wheel? I'll have to pull it apart and take a look
Old Mar 2, 2008 | 08:41 PM
Mark Kovalsky
Yes, that's the one.
fastcam
New Member Introductions
Dec 3, 2009 10:07 AM
fastcam
Dec 2, 2009 08:40 PM
stroker250
Apr 9, 2006 06:50 PM
mikehut
Jan 15, 2006 06:39 AM
doc33
Apr 18, 2001 06:52 PM
