sounds simple, but after tightening and spraying everything I could think might rattle, with no results, I discovered an ice scraper in the plastic tray behind my rear seat. Oh well....mine's fixed, good luck
Wife figured it out. I recently had to change the bulb in the third brake light mounted on the cab. The gray electric snap bracket was rattling against the roof.
At least I got a new pair of shocks out of it.
See---- Like I said Sounds simple, sorry it had to be the wife. (just kidding, mine helps me find my faults all the time)
i had a similar problem that drove me nuts for months on my 95 bronco (drum brakes) CHECK THE REAR BRAKE hardware could be a loose caliper/pad or e-brake lever.
