glow plug changing tools
Old Mar 2, 2008 | 11:16 AM
smoky john's Avatar
smoky john
Smile glow plug changing tools
I have just finished changing all eight glow plugs in my 1004 IDI turbo. I found a set of hollow sockets at Lowe's that are just about perfect to get under the turbo to remove/install the glow plugs by just removing the bolts on the gp. controller and moving it aside. I know it can be done other ways, but $30.00 is a small price for this much help, IMHO. They have two sets, this is the small set. Hope this helps someone, John
Old Mar 2, 2008 | 11:56 AM
PLC7.3's Avatar
PLC7.3
Do you have a part # of the sets.......
Old Mar 2, 2008 | 04:34 PM
smoky john's Avatar
smoky john
part mumber
I will get the numbers tomorrow and post them. John
Old Mar 3, 2008 | 07:37 PM
smoky john's Avatar
smoky john
Okay, the lowe's part # is 266731 The official name is "1/4 in. SAE/Metric Flex-Thru Ratchet Socket Set 21 Pc. (exactly as listed on the tool holder) Kobalt brand. I could not find them on Lowe's web page, even with Pt. No. Also my truck is a 1994, not a 1004. This has to be just about the best thing going for glow plugs. (no I don't own any Lowe's stock) John
Old Mar 3, 2008 | 07:47 PM
sbin's Avatar
sbin
Just changed glow plugs yesterday on non turbo and was thinking about how ratching box wrenches which pivot near head that I saw at Lowes would have helped with one gp under injector lines.Can not imagine working under a turbo setup.The hollow heads were in the same display.
Old Mar 3, 2008 | 08:10 PM
smoky john's Avatar
smoky john
Yes, the killer thing about this set is that the ratchet handle flexes up and down on the head, so it's possible to clear the head while it's inserted between the engine head and the rubber bypass lines, and it's almost as small as a 1/4" ratchet going under the turbo is not much of a problem. John
76f250highboys
15
Dec 23, 2013 07:03 AM
Sullid01
Mar 19, 2013 07:50 PM
wilzy14
20
Aug 16, 2012 06:22 PM
ENG661
Oct 15, 2011 08:49 PM
hunterguy86
15
Jan 20, 2010 05:30 PM
