no fuel pressure
Old Mar 2, 2008 | 09:53 AM
maniac152's Avatar
maniac152
no fuel pressure
Greetings. We have a 2004 f 150 4.6 with no fuel pressure. The pump works fine with a hot wire. We have 12.5 volts at fuel pump connection. We can here the pump come on briefly but no fuel. Anybody had this problem? This is a new pump from ford.
Old Mar 2, 2008 | 10:17 AM
F0rdzTuff's Avatar
F0rdzTuff
which fuel pump?
Old Mar 2, 2008 | 10:37 AM
maniac152's Avatar
maniac152
fuel pump in tank.
Old Mar 2, 2008 | 11:45 AM
F0rdzTuff's Avatar
F0rdzTuff
When you hotwire the pump does it work fine, or does it come on briefly, spit no fuel and shut off? I (we) need more info. If it works good with a bypassed wire, then you have a problem with a relay probably. Find the relay that controls that pump, and replace it. If the pump is shutting off after coming on briefly with it's power wire bypassed or hotwired, then the pump's not grounded right, or the pump is bad. There's also a packing plug in the inlet on those. Was that removed prior to installing the new pump? I always test those for 5-10 minutes before I go through the hassle of installing them. 30% of the time, those pumps don't last very long.
Old Mar 2, 2008 | 12:02 PM
maniac152's Avatar
maniac152
Pump runs fine with bypass wire. alldata shows relay in right kick panel but its not removeable. ground was good. thx
Old Mar 2, 2008 | 12:06 PM
F0rdzTuff's Avatar
F0rdzTuff
Not removeable? That would be bizzarre. Yes, it's probably the relay.
Best of luck to you!!
Claudia Tull
6.7L Power Stroke Diesel
Nov 21, 2016 09:52 AM
9rudy9
Feb 1, 2016 10:46 AM
Tedybear
Dec 14, 2007 08:42 PM
Scruffydog
Bronco II
13
Apr 26, 2004 12:32 AM
sagesprings
Oct 17, 2003 08:06 AM
