Turbo Timer
Old Mar 2, 2008 | 01:26 AM
Vitaliykit's Avatar
Vitaliykit
Turbo Timer and Fuel Pressure Kit
Hi again. Looking for a cheap turbo timer for 2003 with 6.0L. All I need is 30 seconds to 1 minute delay.
Also, would like to purchase fuel pressure gage kit for same vehicle. Any suggestions?
Thanks again for your help.
Old Mar 2, 2008 | 07:06 AM
jdadamsjr's Avatar
jdadamsjr
Morning, this should start a lively debate
asked and answered many times - and will probably generate the same 'discussion'
IMHO (and Chevron, etc.. engineers), a turbo timer is no longer needed on recent vehicles with the new oils and recent style turbos...
Probably the only groups that will say you need them are those that sell them and those that are 'old school' ( NOT that old school is all bad )
Any driving for 30 seconds @ anything less than full throttle will cool down your engine oils such that the turbo bearings will not be damaged by 'coking'.
Granted, old style turbo's with the less than perfect oils of years ago did give pause regarding bearing failure from high temps... but no longer.
Heck, even Banks knows it's not necessary:
http://bankspower.com/tech_TD-fact-Fiction.cfm look at Myth #7
Think that marketing genius would say that if he could sell timers and make a buck off it ?!?
Old Mar 2, 2008 | 07:55 AM
bismic's Avatar
bismic
Originally Posted by jdadamsjr
Morning, this should start a lively debate asked and answered many times - and will probably generate the same 'discussion'
I have not read the articles by Chevron, etc. on this topic. Can you easily find and post the links? I am interested in reading more.
You suggest that SOME cool down is helpful and provides some level of safety factor. I would have to say that AT A MINIMUM, drive it easy for a minute or so after towing or after WOT before shutting down. After that, you get into the discussion on soot buildup from idling.
ALSO, if you do not believe that some cooldown period is necessary, hopefully you are using synthetic oil. Synthetic oils are MUCH more stable at high temps. Stability is not just resistance to coking, it is also the resistance to boiling off some of the important chemicals in the oil.
Old Mar 2, 2008 | 09:36 AM
tippmann87's Avatar
tippmann87
Well if you get a pyrometer, then you can see if your EGT's are low enough to safely shut 'er down...............then adjust the turbo timer accordingly
Old Mar 2, 2008 | 07:08 PM
jdadamsjr's Avatar
jdadamsjr
Will see if I can find the Chevron link again - probably in FTE somewhere from the last discussion, thought the banks link made the point in a less theoretically tone ...
Here's a previous discussion so you can do some reading:
https://www.ford-trucks.com/forums/3...ght=oil+coking
and
https://www.ford-trucks.com/forums/6...ht=oil++coking
By all means - go get a turbo timer - after all, it's your truck
Have had remote starts on all 3 ex's - all had built in turbo timers - never used them
And no - don't use synthetics either - have my opinions for that too...
some cuz my Dad was an engineer at Ethyl corp years ago... but that's another discussion
Old Mar 2, 2008 | 07:31 PM
bismic's Avatar
bismic
jdadamsjr -
Thanks for looking for the link. I do not give the Banks web site that much credibility. Also, when I hear a viewpoint that is opposite of what many suggest, I want to see the references and do the research - just the way I am. It is way too easy to read a statement on the Internet without getting a full understanding with all the details.
The other reason I would like to see the link is to see if a max temperature is defined. How hot can the turbo and oil system get to and still be OK. Clearly there is a limit at some temperature. I just want to know what that is. People w/ very larger injectors, tunes, etc. can generate a lot of heat - I have heard of temps over 1500 pre-turbo.
Even 500 degrees can create problems w/ non-synthetic oils. I just like to see numbers.
Old Mar 3, 2008 | 07:05 PM
Vitaliykit's Avatar
Vitaliykit
So, at the end of the day, is there any suggestions about cheap turbo timer? It does not hurt to have one even if it is useless, but my thing is (I guess I should of mentioned it in the beginning) using WVO. When you driving on WVO and turn off the truck, the engine will still run and switch back to diesel and die after 30 seconds or so.
Old Mar 3, 2008 | 09:25 PM
bismic's Avatar
bismic
Did you read the links posted by jadamsjr??
Some options mentioned -
x-monitor w/ CES (don't know what CES is, but "google it").
viper alarm w/ cool down feature
Old Mar 4, 2008 | 12:33 AM
mnmwhit's Avatar
mnmwhit
If you really want one and are going to spend $. I would suggest getting an auto start. Then you have an accessory that will monitor your batteries and start the truck to keep them charged, warm (or cool) the truck before you get in to drive it, an auto alarm, door locked and unlocked and last but not least you have a turbo timer when you want it.
Old Mar 4, 2008 | 10:24 AM
datsun_1600's Avatar
datsun_1600
LOL I’d love to hear Jun's or any other Japanese engineers opinion on not letting the turbo cool down. In the grand scheme of things the turbo used on the 6 is pretty old school. (ie it isn't water cooled, not even ball bearing) Just my opinion - but I’d let it cool down.
JT
