Help!!!!!!!!!!!!!
Old Mar 2, 2008 | 08:29 PM
2 stroke man's Avatar
2 stroke man
ya, 2 days wont hurt will it?
Old Mar 2, 2008 | 08:30 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i would like to say no, but it all depends on how low the pressure is while driving, if it runs ok down the road but only has idle probs then i would say you are in the clear.
2 stroke man
Old Mar 2, 2008 | 08:32 PM
c00nhunterjoe
how is it driving down the road?
Old Mar 2, 2008 | 08:35 PM
2 stroke man
powerful enough (if there is such a thing). when i come up to stop i gotta kick it into neutral and hold rpms up or else it will die
Old Mar 2, 2008 | 08:36 PM
WALJON's Avatar
WALJON
Is the BB still stuck?? wouldn't this be the problem as well?? especially if it was jammed in there like that
Old Mar 2, 2008 | 08:38 PM
c00nhunterjoe
his spring is bent up pretty bad, cant get the bb out, stuck in place, i think the regulator is sticking on him with the multiple probs.
Old Mar 2, 2008 | 08:39 PM
2 stroke man
i almost cry at this. she dies. and yes, bb is way down in the triangle piece
Old Mar 2, 2008 | 08:42 PM
c00nhunterjoe
it sort-of sounds like its missing in both videos on rev up, is that just the way the speaker picks up the video ro is it rough running all the time?
Old Mar 2, 2008 | 08:43 PM
WALJON's Avatar
WALJON
EWW that's a mess wonder if some shavings from trying to drill and blast got in the regulator I guess he will find out when he gets a new spring
Good luck 2stroke
Old Mar 2, 2008 | 08:51 PM
2 stroke man
otherwise she runs nice. i took the tri-angle piece out to try to drill, then cleaned her good. and come to think of it, on original take-out when i realized it was too high pressured and after getting out the spring i had to but the bolt back in and start it up and shut her down to get the triangle piece out, cause my magnet wasnt strong enough to pull it out
Old Mar 2, 2008 | 08:54 PM
2 stroke man
think i'll need a new triangle piece?
Old Mar 2, 2008 | 08:55 PM
  #28
c00nhunterjoe
if the magnet wouldnt pull it out then it is sticking, the magnet doesnt have to be strong at all, it should slide freely, you will need to make sure the housing isnt scoured.
  #29
2 stroke man
scoured? roughed up?
Old Mar 2, 2008 | 08:57 PM
  #30
c00nhunterjoe
if you tried to drill it then you might want to get a new one especially if it is sticking in the housing, and if the inside of the housing is messed up you will want a new one of those too.
