Sponsored by: Real Truck
Check out the new Stack Covers!
Old Mar 1, 2008 | 05:52 PM
Storm's Avatar
Storm
Yep.. Redneck Mechanix Team was in FULL force today TNT In Round Rock and myself have been going over ideas on building a custom cover to fill the void between the toolbox and the stacks.. After weeks of figuring out the best idea and some spur of the moment light bulbs.. It all came together
Using a sheet of Treadbrite Diamond Plate, Aluminum Angle, Bolts and Marine Trim for Boat Compartments, we were set to work!
We spent the morning drawing out the template for cutting, then with some Redneck ingenuity, TNT went to hack with the Jigsaw.. I must say, it came out 100x better than we imagined.. We used Angle Aluminum that was left over to run the length of the Diamond Plate to strengthen it, it's pretty much rigid now. Also used the Angle Aluminum on the front of the bed and the side to create a plate for the Diamond Plate to sit on and bolt to.. The Diamond Plate was set in completely flush with the top of the bed.. We also had the Plate cut to slide underneath the toolbox, there is a lip on mine that from the inside of the box, we were able to put in 5 Screws to pull the Diamond Plate and secure it to the back of the toolbox. Made the entire section completely stable. You could probably stand on it without it bending.
Here are the photos
Old Mar 1, 2008 | 07:07 PM
vatreefarmer's Avatar
vatreefarmer
Wait a minute, I just read the exact same post on BBC just minutes ago. Its a small world!
Old Mar 1, 2008 | 07:29 PM
TNT in Round Rock's Avatar
TNT in Round Rock
HAHAHAHA well 'cuz I did the cuttin, and I'm TNT on BBC .. SMALLL world huh ????
Old Mar 1, 2008 | 07:42 PM
vatreefarmer
I only go bounce between 3 websites. Here, BBC, and the Redskins fan site. If I see you post on ExtremeSkins, I'll swear you're stalking me!
Old Mar 1, 2008 | 07:49 PM
redford's Avatar
redford
FTE Leadership Emeritus
That looks real sweet!
Old Mar 1, 2008 | 09:46 PM
Storm's Avatar
Storm
Yeah you did the cuttin! I supervised.. Someone has to keep an eye on you..
ALL day long "T.. GLASSES.. T.. GLASSES.. T PUT YOUR *@#&@ GLASSES ON!"
Poor guy gonna have no eyeballs with all the metal shavings we had flying everywhere LMAO
Old Mar 1, 2008 | 09:49 PM
LaxPlaya21's Avatar
LaxPlaya21
Wow those stacks look bad ***! What do they sound like?
Old Mar 1, 2008 | 09:51 PM
Storm's Avatar
Storm
LOL They are LOUD!
I attract attention everywhere..
http://www.youtube.com/watch?v=Li42RZXCy9o
Old Mar 1, 2008 | 09:57 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Looks sweet storm
Old Mar 1, 2008 | 11:04 PM
F350-6's Avatar
F350-6
Nice work. But technically you should have used stainless steel screws for the aluminum, not galvanized.
Old Mar 1, 2008 | 11:07 PM
Storm's Avatar
Storm
Stainless Screws were used on the top of the Cover.. the Galvanized bolts were used on the Angles to attach them to the bed.. Be kinda hard to hit them with water.. Plus Galvanized is a rust resistance coating
Old Mar 1, 2008 | 11:18 PM
F350-6's Avatar
F350-6
If you used stainless on top then you should be fine. The EPDM washers on the galvanized (zinc coated) screws on the bottom should help separate the dissimilar metals and minimize galvanic corrosion down below.
Old Mar 2, 2008 | 07:13 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Hmmmm.... That gives me some ideas! Looks good!
Old Mar 2, 2008 | 07:08 PM
6L PWR's Avatar
6L PWR
Looks finished now Storm!! NICE!!
Old Mar 3, 2008 | 06:08 AM
ben8892002's Avatar
ben8892002
very nice . that cleans it up quite a bit covering the gap between the stacks and tool box.
