checking fuel for winter readiness
I have pulled two samples out of my diesel supply. One from the truck tank I had trouble with, and one from my overhead storage barrel. I have them labledd, and in new, clean mason jars. I have the jars set side by side with a thermometer in my spare fridge. It has read 5 degrees for a couple of hours. The fuel in my truck has blended #1 and #2 fuel. It also was treated with powerservice in the white bottle. The overhead barrel has straight #2, with sureflow added by the fuel man at fill. The tank was nearly empty when refilled. What fuel was left would offer little change in the overall makeup of the whole tank. (15 gallons out of 250) I have also only recently learned that there is no soy in my fuel. Another story all together.
Observations. Both mason jars are icing up a bit on the outside. If I swirl the contents, both spin easily. I can see no difference at this temperature in the depth or duration of the air bubble pattern (whirlpool) caused by the agitation. I was considering a pourability comparison. I was thinking of using a couple of single-use syringes for the test. I could use them to measure the volume accurately. I plan on placing the volumes on a pair of coffee filters to see how long it takes for each fuel volume to perk on down. I plan on using 20 ml of each fuel as a starting point.
Any thoughts?
container on top of a funnel w/ a valve on the bottom of the funnel, this would be ideal.
I put the coffee filters over decapitated water bottles. Each glass syringe held 10 ml (not 20 as I initially thought). The temperature at pour was 5 degrees. I was astonished at the difference in how long it took the fuels to perk through. The "#1/#2 blend with powerservice" from my truck tank took nearly 3 minutes until last drop fell. Repeating the process for the #2 with sureflow, and the 10 ml volume took 2 minutes and 15 seconds until last drop. I have decided that the problems with my truck could have been fuel related. The fuel in my truck was supposedly "the same as we haul to municipal snow plowing entities". I may have had a questionable batch of fuel. I guess it only showed up when pulling loads at lower temps. Driving around this winter, I did not have the bucking. It was a full tank full I purchased in early December.
I guess I will send both of these samples off for a more scientific test (to a lab). I will also pull the EGR as recommended. I don't have the gasket kit today, or I would do it now.
Any more ideas?
http://www.agmkt.state.ny.us/WM/wmpetrol.html
According to Exxon - they use additives:
http://www.exxon.com/USA-English/GFM/Products_Services/Fuels/Diesel_Fuels_FAQ.asp
According to Truckinginfo.net, manufacturers AND distributors use additives:
http://www.truckinfo.net/trucking/ad...s-workpage.htm
Mistakes can be made at the manufacturing site and by the distributor. With these 6.0L engines, it is well worth your while to pay attention to fuel quality.
I might have water in my fuel. Since I ran the tank level down so low this winter, condensation is an issue that I may be fighting. I do use a hydrosorb filter to stop water from coming into my truck. It is a corn starch medium that will stop the flow of everything when it gets water to swell its contents. I have a similiar product soaking in the tank with corn starch sewed into a felt like material. After a couple days, I am to remove it and see if it has gotten heavy with water.
I do have a more visible problem at minus 1. I swirled the jars and can see a white cloudiness through the bottom of the jar that still spins, but not very fast. With all the winterizing these fuels supposedly have, I am surprised to see that they are both acting like they could be waxing filters up at this temp. The fuel guys stated that I "should be able to drive to the Yukon territory without reservation with the fuel they provided". I think they will be surprised that I wouldn't have made it much North of Minneapolis!
Interesting articles bismic. I am going to print them out and give them a second read after Church. Thanks for the help by sending them. Slang or jargon used in the field is often missused in this or any field.
I would like to show both dealers my cold samples. Keeping them this cold for very long will be a challange. The fuel salesman will come to my house, I am sure. The Ford dealership is only 3 miles from here. Maybe the styrofoam cooler with enough ice, and ziplock bags around the sample bottles would do the trick.
I am starting to feel like I am on Mythbusters!
Thanks for the help.
