Sponsored by: Real Truck
Cat Testing
Old Mar 1, 2008 | 12:27 PM
F-SUPER DUTY's Avatar
F-SUPER DUTY
Cat Testing
Anyone ever try disconnecting cat from Y pipes and driving to see if cat is bad?Im sure it will be loud.Would this test be any good?
Old Mar 1, 2008 | 12:37 PM
elmo8641's Avatar
elmo8641
yeah, it works if you think you have a plugged up cat.
Old Mar 1, 2008 | 12:39 PM
F-SUPER DUTY
Thanks,going to try later today.
Old Mar 1, 2008 | 01:08 PM
aquanaut20's Avatar
aquanaut20
If you remove the upstream O2 sensor and drive , it will be quieter and show the same pressure reduction.
Old Mar 1, 2008 | 01:29 PM
cartmanea's Avatar
cartmanea
I like to test them by pulling them out and jamming a large screwdriver through them multiple times and then putting it back on
Old Mar 1, 2008 | 02:05 PM
F-SUPER DUTY
Just finished driving.Truck still falls on its face with more than half throttle.99 F250 5.4 OBD 1 no codes or light.
Old Mar 2, 2008 | 12:50 AM
elmo8641's Avatar
elmo8641
first thing i would check would be the mass airflow sensor. i don't know what kind of scanner you have, but if you have live data then look at your mass air flow sensor. try to clean it and maybe replace it. does it idle good?
Old Mar 2, 2008 | 11:03 AM
F-SUPER DUTY
I already cleaned MAF.Truck idles good and has good low end power just nothing over half throttle.Im going to check throttle position sensor next.Maybe drive with a fuel pressure gauge on windsheild to see what i have at WOT?8 MPG sucks!
Pridnjoy
Apr 13, 2014 12:09 PM
bphelan
1997 - 2003 F150
Aug 21, 2011 02:13 AM
VikingBabe
Feb 13, 2008 08:39 AM
gerridm
Exhaust Systems
Sep 18, 2000 05:34 PM
