first thing i would check would be the mass airflow sensor. i don't know what kind of scanner you have, but if you have live data then look at your mass air flow sensor. try to clean it and maybe replace it. does it idle good?
I already cleaned MAF.Truck idles good and has good low end power just nothing over half throttle.Im going to check throttle position sensor next.Maybe drive with a fuel pressure gauge on windsheild to see what i have at WOT?8 MPG sucks!
