C6AE 6090 R Heads
Old Mar 1, 2008 | 09:19 AM
vegas852's Avatar
vegas852
C6AE 6090 R Heads
Need a little help from you guys. Wondering if these heads
C6AE 6090 R
will work on my 74' F250 with a 360?
Thanks in advance
Old Mar 1, 2008 | 07:33 PM
whd507's Avatar
whd507
Valves 2.02, 1.55
Int port 2.34 X 1.34
Exh port 1.84 X 1.28
I think with your dished 360 pistons, you will still have fairly low compression. they may or may not be of any performance gain on a 360.
what is for sure, if they have not had hardened seats machined and pressed in, they will not last long at all with regular use and unleaded gas.
its a general purpose 1966 passenger car head, intended for use on 390-427LR with flat-top pistons. an old trick that may still work to get flat tops for a 360, get 352 pistons oversized to the 360/390 bore. 352 pistons are generally flattops, 360s not so much.
Old Mar 2, 2008 | 08:20 AM
vegas852's Avatar
vegas852
Thank much for the info. I appreciate it much.
cj005
Nov 25, 2010 01:47 PM
keisha9
Jan 26, 2008 05:50 AM
nofortunateson
Nov 30, 2007 09:38 AM
mswift
Dec 21, 2006 01:42 PM
GWB
Oct 15, 1999 12:59 AM
