Help!!!!!!!!
Old Feb 29, 2008 | 11:37 PM
blackmagic84's Avatar
blackmagic84
Help!!!!!!!!
ok i have a 1994 bronco yes.. im gonna cash crap for posting in the f-150's but.... this question is universal so .... but as for my dilema .... my little black handle on my wing window on my drivers side... sheared off tonight on my way home from work ... and now i cant latch that window closed on my rig... and its -10 degrees out.... so if anyone has a diagram or a weblink.. or something as to how those wing windows and window trim comes apart.. that would be greatly appreciated.. because i have a 94 f-150 and its a parts truck so im jacking one from that .....
thanks
Roger
Old Feb 29, 2008 | 11:59 PM
TexasGuy001's Avatar
TexasGuy001
I haven't had them apart, but I do know that LMC has them.
Old Mar 2, 2008 | 04:23 PM
Miamited's Avatar
Miamited
All that is inside is a spring and the chrome button. I just replaced the one on my left side as it sould not lock. I ordered the handle set. It included the spring and button. All you need is a thin punch to derive the drift pin out. Then it just comes off in your hand. Not even a fie minute job.
Old Mar 3, 2008 | 09:42 AM
Conanski's Avatar
Conanski
If the post sheared off then you either have to weld it back on or replace the whole vent window assembly. There are 2 screws on the forward door edge under the door seal, and 1 bolt right below the vent window lock. Start by removing the inner door skin, roll the main window down, remove the 3 fasteners mentioned above and pull back on the top of the vent window. Reach inside and slide the main window glass off the regulator and remove it from the door. Now remove the rubber seal from the front track and then turn the vent window assembly 90 degreed and work it out of the door. You may have to loosen or remove the bolt holding the mirror stabilizer.
gangstakr
Mar 10, 2014 05:21 PM
66-Ol'Henry
Jul 7, 2011 01:45 PM
dbarracuda
13
Jan 14, 2003 10:44 AM
