Bad Misfire!!!
Old Feb 29, 2008 | 06:22 AM
88PONY's Avatar
88PONY
Cool Bad Misfire!!!
ok, i got a 91 f250 5.0l i've tuned this thing up 5 times changed everything and it still misfires under a load. it doesn't matter if its a hot or cold engine or if its hot or cold out it still does it. im lost ad tired of replaceing parts. any help would be great!!!
thanks
Old Feb 29, 2008 | 06:30 AM
BChance's Avatar
BChance
What have you replaced, and with what?
Old Feb 29, 2008 | 06:32 AM
Animalistic's Avatar
Animalistic
From what I have seen, it is easy to get the plug wires crossed in these. Double and triple check your fireing order and make sure you are starting at the right place on the cap.
Old Feb 29, 2008 | 07:38 AM
88PONY's Avatar
88PONY
i replaced cap/rotor,wires,plugs, and coil. all parts were wells and motorcraft. i heard a lot about crossing wires andit being bad. i habe an 86 f250 and it never had a problem. this truck is driving me nuts! is there a certain brand wire i should use?
Old Feb 29, 2008 | 01:00 PM
quicklook2's Avatar
quicklook2
what kind of plugs? copper or plats?
are you positive you have the wires on correctly?
is timing correct?
Old Feb 29, 2008 | 02:04 PM
fmr9's Avatar
fmr9
If the ignition is good, then maybe the compression, or the fuel is not.
Compression check is easy and quick. Not sure of an easy way to check the injectors.
Just an idea.
Frank
Old Feb 29, 2008 | 02:15 PM
quicklook2's Avatar
quicklook2
any codes?
Old Mar 1, 2008 | 07:06 PM
88PONY's Avatar
88PONY
no codes....and i fixed it....it was the 7 and 8 cylinder wires next to each other....
thanks for the help )
Old Mar 1, 2008 | 07:48 PM
quicklook2's Avatar
quicklook2
great job!
