Error Codes w/o Check Engine Light ????
Old Feb 28, 2008 | 10:43 PM
quality1construction's Avatar
Smile Error Codes w/o Check Engine Light ????
Is it possible to have error codes on the system without the check engine light being on. It comes on when first cycle the key, but thyen goes off while turning the truck over.
2000 7.3, 6spd, cc 4x4
Thanks
Old Feb 28, 2008 | 11:04 PM
SVLERF250PWRSTRKE's Avatar
SVLERF250PWRSTRKE
Some one else should chime in but I believe it may be a soft code, or maybe just an intermittent problem
Old Feb 29, 2008 | 06:17 AM
Pocket's Avatar
Pocket
Yep, "soft" codes trigger without setting off the SES light. I have two that constantly trip on my truck due to modifications I've made.
What codes are you seeing?
Old Feb 29, 2008 | 08:46 AM
Just to check, someone told me to check the turbo, would that have anything to do with this?
