Headers for '47 1 Ton
Old Feb 28, 2008 | 10:29 PM
PeeVee's Avatar
PeeVee
I'd like to fit Red's headers to my truck. Red's weren't sure if they'd fit, being designed for the PU. I think the steering box might be different so they won't fit. Can someone confirm?
Thanks
Peter
Old Feb 28, 2008 | 11:01 PM
mtflat's Avatar
mtflat
The F4-6 steering boxes are larger than the F1-3's. If you need I'll get you a measurement from the box to stock exhaust manifold on an F2. Compare it against your F4. Then I can get you a measurement from the strng box to red's headers on an F1. From that you should be able to tell if you have enough room.
Old Feb 28, 2008 | 11:14 PM
PeeVee's Avatar
PeeVee
That'll do the trick for sure, mtflat. I'd appreciate it if you'd go ahead and do that. Many thanks
Peter
Old Feb 29, 2008 | 12:12 AM
PeeVee's Avatar
PeeVee
Looking further mtflat, I don't think the measurements will help. Different trucks. But I can't see anything in my literature to indicate there's a difference in steering boxes between the pass, PU and commercial (1Ton) so i think I'll go ahead and order a pair. Red's said they'd take it back if there was a problem.
thanks again
peter
Old Feb 29, 2008 | 09:39 AM
mtflat's Avatar
mtflat
Sorry, I forgot what forum I was in. You're right, half-ton and one ton should have the same gearbox so I'd bet you'll be ok.
Tim
Peter Gill
Jul 5, 2012 06:49 AM
WA.Ranger
May 11, 2012 12:12 AM
PeeVee
Aug 19, 2009 09:53 PM
f350peter
Jan 19, 2007 04:32 PM
Peter Bowler
1978 - 1996 Big Bronco
Aug 11, 2003 05:22 AM
