shifter slip
Old Feb 28, 2008 | 04:42 PM
Flea's Avatar
Flea
shifter slip
So, I have the classic shifter slip. The orange indicator and the gear selector levor move together but the play seems to be in the column. As you select down from park, it is hard to tell and I have been having problems when I try to shift to Drive and I end up in second gear.
I hope this is clear.
Question: How do I fix this problem?
Old Feb 28, 2008 | 04:50 PM
JethroF250's Avatar
JethroF250
It's your shifter linkage cable. My truck was doing it and I neglected to fix it. Then when I was towing my 7500 lb tractor I got stuck in low gear (1). I suggest takin it to the nearest shop and have them retune the shifter as well as put in a new cable. It's only like $150-$225 to do everything depending on where you go.
Old Feb 28, 2008 | 04:52 PM
Flea's Avatar
Flea
I can't do it myself?
Old Feb 28, 2008 | 04:54 PM
JethroF250's Avatar
JethroF250
You might be able to. I'm not sure. I was just concerned when it happened to just get it to the shop and on the lift before my tranny burned up. Although they did say they had to take off part of the steering column inside the cab in order to reach the top part of the cable.
Old Feb 28, 2008 | 05:04 PM
Action4478's Avatar
Action4478
Look under the dash for ...this .....
see if they are loose ...
Old Feb 28, 2008 | 05:07 PM
Flea's Avatar
Flea
Yep already had that problem and fixed it. I believe this one to be in the column. I have checked those screws.
Old Feb 28, 2008 | 05:21 PM
Action4478's Avatar
Action4478
I 've read there are some plastic bushing's that wear out inside the column...One of these days I'm going to take mine apart & do a write up on it ...
I hear about it alot ...
Old Feb 28, 2008 | 05:41 PM
Flea's Avatar
Flea
I look into it. I need a write up on how to get the column apart
Old Feb 28, 2008 | 05:54 PM
Action4478's Avatar
Action4478
I have a write up on it on paper , but it's 23 pages ....
Old Feb 28, 2008 | 05:55 PM
c00nhunterjoe's Avatar
c00nhunterjoe
are you complaining of the physical shifter being too loose or the indicator not showing the proper gear?
Old Feb 28, 2008 | 05:57 PM
Action4478's Avatar
Action4478
I might be able to E mail it to you.....
Old Feb 28, 2008 | 06:31 PM
Todd525's Avatar
Todd525
he said that the slector arrow moved with the selector lever COON, so either the bushings are wore, or probelms in the linkage dept. You can fix this easily either way. Neither are brain surgery, just ask questions, as there is a write up for anything and everything about these trucks on this site.
Does the selector feel like it has little or no resistance, or does it just flop around on its own??
Old Feb 28, 2008 | 06:40 PM
Action4478's Avatar
Action4478
Why don't you explain it ,since you already know what it is ...I'm all eyes ...
Old Feb 28, 2008 | 06:45 PM
c00nhunterjoe
his post is unclear to me, he says the lever and indicator move together but he cant tell what gear its going into. to me that could be as simple as the indicator is out of alignment and is showing the wrong gear. it could also be a wore out cable, but even so you should feel the clicks from each detent in the tranny. thus the reason for my asking for clarification
Old Feb 28, 2008 | 06:57 PM
Action4478's Avatar
Action4478
Mine is loose from 175,000 miles & plowed since new ...Its not the cable.. the bolts to the shifter are not loose ,,,lets me believe the bushings & the detent are worn...The selector goes with the shifter as would be expected ,,,detent is not as tight as I would like...
