C90E vs E5TE
Old Feb 28, 2008 | 01:27 PM
Handegard's Avatar
Handegard
C90E vs E5TE
I have a set of each. I'll be using both, but I don't know which car to put which on.
Both sets are off a 302, btw.
The C9's have a smaller combustion chamber, I can see that right off the bat. But are there any other differences I should know about before deciding which go on my '69 Mustang and which go in my DD?
Old Feb 28, 2008 | 04:40 PM
HemiEater's Avatar
HemiEater
the E5s will have hardened exhaust seats...
Old Feb 28, 2008 | 04:49 PM
Handegard's Avatar
Handegard
So, I know what that means, but not how it's benificial. More resistant the heat?
The E5s had the smog holes on the back too. Those were plugged when I got them.
I also have a set of heads out of a 1988 LTD. Not sure what they are, as they're still attached to the motor...
Old Feb 28, 2008 | 05:25 PM
baddad457's Avatar
baddad457
The 88 LTD heads are dandy boat anchors. Good for bottom end torque, but not much else. E5TE's are the same head as the later E7TE. 64 cc chambers. If those C9OE's have 8 intake bolt holes and "L" shaped coolant ports, they're the "good" 351W heads with 1.84/1.54 valves and larger ports.
Old Feb 28, 2008 | 07:27 PM
ssidney's Avatar
ssidney
lead used to lube valve seats somewhat, with the advent of unleaded and alternate fuels alternate means of preserving valve seats became necessary
Old Feb 28, 2008 | 08:47 PM
Handegard's Avatar
Handegard
AH! I remember that.
My grandfather told me he had the head's redone when he had headgaskets done, and he had it setup to run unleaded. I though he had said something about replacing the valves, but it's been awhile.
Old Feb 29, 2008 | 10:50 AM
Conanski's Avatar
Conanski
For the mustang I bet you want more HP so whatever set you port will make more, and it's not hard to improve any of these casting with a carbide bit and some elbow grease.
Old Feb 29, 2008 | 06:19 PM
HemiEater's Avatar
HemiEater
If it were me I would do the E7’s up…. They are pedestal mount so easy roller rocker install, no guide plates, no hardened push rods and no exhaust seats even if you go to a 1.60 exhaust valve. I opened my e7s to 1.94 1.60 valves the machinist said he was still in the factory induction hardness (or whatever they call it) when he was done… and after 3 years they are still holding up just fine…and the cost of cutting the seats and bowls to 1.94 1.60 is no more than a regular valve job. You would just need to buy the valves, spring, retainers, locks and roller rockers. Then port them, there is plenty of info out there on porting small block heads. You would be surprised how much of a difference it will make.
The e7’s would be the cheapest to do.
diesel_dan
Feb 27, 2018 11:55 AM
jayloveland
Jun 6, 2015 10:46 AM
Mikey_23_ny1
Apr 26, 2015 07:35 PM
windyhill
26
Nov 13, 2010 06:20 PM
oldmansimek
Mar 9, 2006 10:42 AM
