56 hood
Old Feb 27, 2008 | 09:26 PM
Mick1930's Avatar
Mick1930
56 hood
Is it true that all of the F100 hoods are interchangable and fit?
I have a 56 and was told that the back of the hood should have a few rounded carrage bolts in the back mid center line. The hood I have does not have this. So do I have the wrong hood and is there any shape difference from an original 56 hood??
Thanks.
Old Feb 27, 2008 | 09:37 PM
Randy Jack's Avatar
Randy Jack
The 53-55 hoods are identical. The 56 hood is ALMOST exactly the same. The 56 has the two carriage bolts either side of the center rib at the rear crossmember for added stiffening. I also heard that the holes for the hinges are a bit larger, but other than those two things (and the badging), they all interchange.
Old Feb 27, 2008 | 09:53 PM
Mick1930's Avatar
Mick1930
Hi Randy,
Is a 56 F250 hood the same as an F100? and would it fit?
Old Feb 27, 2008 | 10:07 PM
Randy Jack's Avatar
Randy Jack
Yes. The F250 hood is identical to the F100.
Old Feb 27, 2008 | 11:12 PM
yield2s's Avatar
yield2s
also I heard the 53-55 hoods are a bit thicker
Old Feb 28, 2008 | 02:19 PM
GarageTime's Avatar
GarageTime
Maybe that explains the need for the stiffening on the 56?
Old Feb 28, 2008 | 04:07 PM
yield2s's Avatar
yield2s
and the notorious cracks along the edges
Old Feb 29, 2008 | 07:29 PM
56panelford's Avatar
56panelford
I have four hoods, two from 56 f100, one from a 56 f600 and one from a 53 f100. The only hood that had the carriage bolts was the one from the 53, I've mentioned this in previous posts with no response, could there have been a difference between the trucks built in the US as compared to the ones in Canada. I would also add that the hoods all the way up to the F-660 will fit the F-100. Please do not take my statements as arguementive it's just that my observation has been the opposite as stated. Friends??
John
Old Feb 29, 2008 | 08:01 PM
Fomoko1's Avatar
Fomoko1
I`ve heard that the F350 have the carriage bolts, is this true or false?
Old Feb 29, 2008 | 09:08 PM
LiftTech's Avatar
LiftTech
My '56 F-350 has two carriage bolts at the back of the hood, one on either side of the center line.
Old Mar 1, 2008 | 11:06 AM
bigwin56f100's Avatar
bigwin56f100
All 56's have the carriage bolts, Once the 56 style hoods were in production, they were the replacement hood for the 53-55's. The 56 hood Part number B6C came drilled for the front hood emblem but not the side emblems. depending on the model year truck it was going on it had to be drilled for those model year emblems.
Kevin Bigwin
Old Mar 1, 2008 | 11:44 AM
Mick1930's Avatar
Mick1930
Can someone show a picture of the top and inside of the carrige bolt reinforced portion?
Wondering if it is a metal piece that can be made ..so I can make mine look stock with adding this detail.
Thanx
