Patch panel help (maybe use scrap parts?)
Old Feb 28, 2008 | 10:37 PM
rods4life's Avatar
rods4life
Exclamation Patch panel help (maybe use scrap parts?)
I need to make patch panels for my running boards (the ribbed area) and my rear fenders (I need the front and rear sections including the flared edge). Any suggestions on how I can make these? Is anyone like me (never throws anything out) and have any scrap metal that these areas can be salvaged from?
I know where some fenders are but they are to nice and I would feel bad cutting them up.
I know they make a patch for the rear fender where the running boards meet, but this is a custom piece I am working on. I Want to extend both the front and back lower parts of the fender by 4-6 inches.
Thanks
AL
Old Feb 29, 2008 | 08:23 AM
AXracer's Avatar
AXracer
If you want custom patch panels then they will need to be handmade or modified from stock pieces, exactly what "custom" means. In the case of the rear fender to running board extension, you might be able to use the available patch piece at the connection point if the two parts will meet as per stock then fill in the extra area above with formed sheet metal. For the running boards you might cut out the ribbed section completely and add a custom insert of polished diamond plate. That's the fun of custom, you don't need to put it back to original condition.
Mid Fifty and others sell repro running boards, would be much cheaper and easier than repairing rusted out ones if you want stock look.
Old Feb 29, 2008 | 09:46 PM
rods4life's Avatar
rods4life
AX very good points and very true but I for got to mention that I dont have a lot of money and this is a low buck project.
Thanks
AL
Old Feb 29, 2008 | 10:36 PM
AXracer's Avatar
AXracer
Thanks
AL
All the more reason to make your own patch panels! A 1/2 sheet of 18 ga cold rolled steel is pretty inexpensive and will go a long way. Some sheet metal fab shops will even give or sell for a couple dollars their "drops" or smaller leftover pieces. Just don't get galvanized metal. Click here on member
keith56_cruz_cab and take a look at his gallery to see how he reworked his fenders and running boards and built custom panels.
I haven't had to do much patching except redoa couple previously patched bullet holes, but I have in process pix of some of my custom work in my galleries.
Old Mar 1, 2008 | 08:50 AM
reamer's Avatar
reamer
I make a front fender to running boad patch panel (for big trucks). You might be able to modify them. Look in my Classified ads.
Reamer
Old Mar 1, 2008 | 10:02 AM
AXracer's Avatar
AXracer
Reamer, I would have suggested you patch panels, but his profile says he has a 54.
Old Mar 1, 2008 | 12:49 PM
reamer's Avatar
reamer
Oooops, Sorry! Worth a free plug anyway!
Jeff and Nicolle
16
Mar 17, 2013 09:58 AM
Don Rocco
Feb 13, 2012 09:54 PM
jimprowse
May 18, 2011 05:18 PM
dick1950
Mar 15, 2008 10:21 PM
sancochojoe
Mar 9, 2005 09:08 AM
