Fuel Pick-up tube in tank
Old Feb 27, 2008 | 08:26 PM
FitchBanjos's Avatar
FitchBanjos
Question Fuel Pick-up tube in tank
Is the pick up tube located where the metal line goes into the top of the fuel tank?
Old Feb 27, 2008 | 08:37 PM
BobbyFord's Avatar
BobbyFord
If you're refering to an in cab tank, the pick-up is a long tube inside the tank directly below where the metal line screws into the tank.
Old Feb 27, 2008 | 08:39 PM
FitchBanjos
yes Bobby, the tank behind the seat in the cab. I read where people have cleaned thes tube and was wondering how they accessed it.
Old Feb 27, 2008 | 10:22 PM
BobbyFord's Avatar
BobbyFord
Not too sure how they may have cleaned it, as it is not removable.
Maybe a big 'ol pipe cleaner?
Old Feb 28, 2008 | 02:37 PM
jjblack's Avatar
jjblack
You might try a rifle cleaning rod
Old Feb 28, 2008 | 06:00 PM
FitchBanjos
Well, I checked mine and it was not dirty. Infact, the tank was very clean inside so, I decided to tear into the carb. I found the power valve was blown and, there was a lot of silt in the botton of the bowl. After the overhaul, it runs like new.
Old Feb 28, 2008 | 06:05 PM
BobbyFord's Avatar
BobbyFord
Nice, glad everything worked out well for you.
Old Feb 28, 2008 | 07:32 PM
66lastepside's Avatar
66lastepside
I had a clogged pickup tube and used a piece of threaded rod just smaller than the tube and a lot of carb cleaner. It took some time but it worked!
Old Feb 28, 2008 | 07:36 PM
FitchBanjos
Thats a good idea stepside!
