alt. belt
Old Feb 27, 2008 | 07:16 PM
chucky0094's Avatar
chucky0094
alt. belt
The alternator belt really jumps alot. I changed belt and re tightened the alternator still the same. Is there a fix for this. seems like a big spand for the belt from the crank to the alternator. If there was a idler pully maybe that work work.
Anyone ever tried this and if so what did you use?
Thanks alot guys
This forum has helped this dumb Ga. boy out a bunch.
Old Feb 27, 2008 | 07:34 PM
jayzeller79's Avatar
jayzeller79
sounds to me that one of the pullys are not spining free (draging)
and is making your belt jump...
Old Feb 27, 2008 | 07:50 PM
Franklin2's Avatar
Franklin2
Try this link.
https://www.ford-trucks.com/forums/6...ighlight=idler
Old Feb 27, 2008 | 08:31 PM
PLC7.3's Avatar
PLC7.3
Tried the link left me confused.........
Try looking up an idler pulley setup that is done to aleveate the problem on Google try ... idler pulley Snotzalot or okiegringo
Old Feb 27, 2008 | 08:37 PM
Franklin2's Avatar
Franklin2
Looks like the photolink is dead. Maybe one of the other guys saved it.
Old Feb 27, 2008 | 11:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The jumping is the result of the power pulses as each cylinder fires.
I run premium belts from Gates, it still jumps but nothing like it did with the cheapies on it.
The alternator belt is a good one to run premium belts on anyway, since the alternator drives the vacuum pump.
If you loose the alternator belt braking goes to almost nothing with no vacuum assist.
Old Feb 28, 2008 | 08:06 AM
tjc transport's Avatar
tjc transport
i ain't rite
i agree with dave. premium belts, and keep an eye on the condition of them.
i have only lost 1 belt in 20 years.
Old Feb 28, 2008 | 12:02 PM
tbone91's Avatar
tbone91
Mine didn't jump around much until the alternator bearings burned up leaving me stranded with no charge and no vacuum assist. After replacing the alternator and both belts, the belt jumps some. My guess is that the PO had tightened the heck out of it. Expensive lession...some vibration is normal. Like Dave S said, it only jumps with the vacuum pump hooked up.
DSMMH
Nov 21, 2014 10:36 PM
Vashon Islander
Aug 23, 2014 09:01 AM
Ordnance
Jan 24, 2014 01:25 AM
rolltide3006
16
Apr 23, 2011 10:50 AM
rluckey1
Dec 5, 2007 02:37 PM
