Offroad & 4x4
Bumper Build
Old Mar 5, 2008 | 03:19 PM
  #46
Josh88Ford's Avatar
Josh88Ford
Flux or gas, you still going to get spatter. If you want the job to look right, it will needed to be sanded anyways...
I dont like the idea of the rear bumper with the hook in the middle. take a hammer and I bet you can easily bend that hook with a couple of bends. I would have put a hitch receiver. being you already have two d rings.
That defeated the purpose of towing anything, and any side pulling.
Old Mar 5, 2008 | 04:12 PM
  #47
kjett's Avatar
kjett
Josh, the hook isn't to tow anything. This is for my mud racer that I am building. It is mainly to box and strengthen the rear of my frame and to give me a hook point if something happend to the truck and they have to pull me back out of the pit. In most mud races around me, the tire size classes have to pull a cable through the pit in case you don't make it through, thats all the purpose it serves, so the receiver hitch would be even more added weight that I want to reduce.
Old Mar 6, 2008 | 11:04 AM
  #48
ghunt's Avatar
ghunt
Well yeah but the cooking spray can prevent splatter getting on things you don't want it on. For example, if I'm welding on/around threaded fasteners, I like to spray the cooking spray on the threads. It prevents 95% of the splatter from actually sticking to the threads, and if any does it's easy to knock off.
Old Mar 6, 2008 | 03:26 PM
  #49
Josh88Ford's Avatar
Josh88Ford
i'd rather put bolts or cover the threads. Either way you need to sand, sandblast ect if you plan on doing coating with it with anything. If you have your welder set right, you should be able to take all the spatter off with a scraper
i'll have to try the cooking oil trick. I bet it smells good after a while!
Old Mar 6, 2008 | 07:21 PM
  #50
kjett's Avatar
kjett
Makes ya hungry. Might as well grab and egg and bome bread and fry up an egg sandwich wehile your welding.....
Old Mar 7, 2008 | 12:29 AM
  #51
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
now thats a good idea, cook lunch and work on the rig at the same time, now that is multi tasking at its finest!!! Might even get some "freshly welded steel" flavor mixed in with the egg. Good stuff!
Old Mar 7, 2008 | 06:26 AM
  #52
meanv10's Avatar
meanv10
I hope you guys are welding on food grade stainless, the stuff I'm weldin on would get rust in my eggs!
Old Mar 7, 2008 | 08:50 AM
  #53
brazzealI6f150's Avatar
brazzealI6f150
im posting pics today as soon as i get to my bayhouse.. my camera isnt downloading to this computer for some reason..
Old Mar 7, 2008 | 08:55 AM
  #54
dragogt's Avatar
dragogt
jesta litttle more iron for your diet thats all.
texasman
Nov 12, 2013 11:11 AM
Biggziff
6.7L Power Stroke Diesel
Feb 18, 2011 09:31 AM
texashottie
1978 - 1996 Big Bronco
Apr 6, 2005 12:10 PM
perryphilip
Jun 4, 2002 01:26 PM
TexasGuy001
Feb 14, 2002 07:42 PM
