Front Axle Question
Old Feb 27, 2008 | 06:13 PM
cjg1999's Avatar
cjg1999
Front Axle Question
guys,
I posted this in the differential forum but got minimal response, I am looking to updgrade to some 4.10's on the cheap for my 94 F150 4x4, can i get the front differential from an F250 with a Dana 44 and swap it into my 1/2 ton Dana 44? I don't recall seeing many F150's with 4.10 gears stock. Thanks in advance.
Old Feb 28, 2008 | 01:06 PM
cjg1999's Avatar
cjg1999
no one has any information on this?
Old Feb 28, 2008 | 01:08 PM
andym's Avatar
andym
Yes you can. From the spindle out is where the axles differ, so you can either swap the outer parts over after swapping the whole axle, housing and all, or you can tear down your axle and use the center section from the F-250 Dana 44.
I don't know which would be more work.
Old Feb 28, 2008 | 01:43 PM
cjg1999's Avatar
cjg1999
Thanks, I always thought the TT arms were shorter on the F250 as well. I am not sure which swap method would be easier either.
Old Feb 28, 2008 | 01:46 PM
andym's Avatar
andym
Oh, duh.
You can't use the F-250 housing because it's leaf sprung. Your F-150 uses coils. So you have to tear your axle down, pull the axle shafts (replace u-joints if they're old/questionable) and swap center sections.
Old Feb 28, 2008 | 02:28 PM
superduty4x4's Avatar
superduty4x4
Originally Posted by andym
Oh, duh.
That would also keep you from having 8 lug wheels on front and 5 lugs out back (unless you swapped for an F250 rear also). I would do as andym said though.
Old Feb 28, 2008 | 04:03 PM
tjc transport's Avatar
tjc transport
i ain't rite
Oh, duh.
are we having a senior moment there Andy??
Old Feb 28, 2008 | 04:53 PM
andym's Avatar
andym
Jeez, and I'm not even that old!
