Flexplate for 390.
Old Feb 27, 2008 | 03:15 PM
TRADITION's Avatar
TRADITION
Flexplate for 390.
Anybody know what a flexplate on a 390 goes torqued at
Old Feb 27, 2008 | 04:04 PM
Lance Hogan's Avatar
Lance Hogan
According to Steve Christ , author of How to Rebuild Big Block Ford, states that you should torque the flywheel bolts to 75-85 ft-lbs. (p. 148)
Old Nov 13, 2020 | 04:03 PM
Thunderkiss1965's Avatar
Thunderkiss1965
I always add a couple drops of red locktight. I put it on anything that spins or would be a real bear to get to to retighten. But that's just me.
Old Nov 16, 2020 | 05:31 PM
v84960's Avatar
v84960
I agree on the loctite. As for torque specs, on stuff like that with bolts going into iron or steel, I use the German torque spec of gudentite. Not on head bolts or anything like that of course.
Old Nov 17, 2020 | 09:48 PM
Thunderkiss1965
Then hit it with the impact a couple times
Old Nov 23, 2020 | 03:21 PM
baddad457's Avatar
baddad457
Never used locktite on flywheel or flexplate bolts and never had one come loose using the stock torque specs
I have used teflon paste on small block flexplate/flywheel bolts to seal the threads (holes go through the flange on roller blocks) Never had them come loose either.
Old Nov 23, 2020 | 04:23 PM
69cj's Avatar
69cj
If I were to use locktite it would be the blue.
Old Nov 30, 2020 | 07:33 PM
Fordwideman's Avatar
Fordwideman
Trailering
Might consider the NEW ORANGE LOCKTITE.
4x4slik
Jun 13, 2016 07:24 PM
allwthrrider
Jun 9, 2011 12:26 AM
gambianer
Jun 30, 2005 02:37 PM
chico76
Oct 6, 2004 08:28 PM
