which is better for low end torque? I have read in these boards about some people rebuilding 400's with both the 351 4v closed chambers and others going with aussies. I hope that this is not a stupid question; I am new to this motor head stuff and i have a '79 bronco that is dead and rusting away and i want to revive it into a hoss torque monster but i only want to do it once! Thanks for the patience.
IF you can get yourself a set of Aussie heads then I'd use them over the 4V heads. with the 4V heads you have to be up in the Rpm's( Above 5000 ) to get the usefulness out of them.
>them.
Shazam - I too am a fan of the Aussie's and have a set waiting to be machined. ...but I've always wondered if the added cubes of the 400 may make the 4V heads beneficial at lower RPM's since they should have ~15% higher port velocity at a given RPM. Thoughts?
the aussies on ebay, are they the right size? Are there different sizes? The ebays are 58.4 cc, would this be the ones i need for my 351m to 400 transformation? Is $315 for these heads a good deal? Thanks again for the enlightenment, ford gurus!
>ford gurus!
Yes - that is a very good price and they are the heads you want. Got mine for about $340 and they had been cleaned and magnafluxed. Shipping is typically $60 to $80...
got em on ebay for 275...guy is charging 98 bucks to ship em... i think the shipping is bs...did not say if it was magnufluxed, just clean and crack free...from NC to MT... came with various parts and a rebuild manual... think i got hosed? it promised that no machine work has been done..
I purchased the same heads from the same guy in NC. Shipping to MD was aroung 55.00. They were perfect! They are on a Modified 351M. I had them machined, 3 angle valve job ported and polished. They bolted right up with no problems. Art
