OBDII question
Old Feb 26, 2008 | 11:45 AM
fishman002's Avatar
fishman002
OBDII question
I have no power to my cigarette lighter or OBDII but my number 3 fuse is good. What is the color of the wire that provides power to the OBDII port? I need to put my truck in tow setting deperately. Can anyone shed some light on where the problem would be? I read somewhere that there is a problem with the wiring harness getting shorts in it after some time and causing these types of problems.
Thanks.
2000 PSD F-350 4R100
Old Feb 26, 2008 | 12:11 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
IMO, There's probably something wrong with the fuse block if the fuse it still good.
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Feb 26, 2008 | 12:24 PM
novice psd's Avatar
novice psd
would probably be an open rather than shorted or the fuse would blow.
Old Feb 26, 2008 | 01:40 PM
ghb2's Avatar
ghb2
Thanks.
fishman: check the wiring just above the OBDII port and you will see factory splices. Tug lightly on the splices to see if a wire has come loose. I had the exact same thing happen to me just a couple of months ago and the wire providing power to the port had separated in the factory splice. I cut striped the wire and used a #22 butt connector to resplice and all worked. I don't remember what color the wire was.
07FX4
Feb 17, 2012 05:41 PM
A/Ox4
16
Jun 5, 2011 09:56 PM
4inchlovin
Aug 1, 2009 07:50 PM
tagunderson
Mar 9, 2008 09:24 AM
santacruzf250
Jul 1, 2007 08:40 PM
