If you have the trans mounted speedo cable, over time the gears will get chewed up both inner and cable end...... You can get the parts at ford or trans shops. They go by color so take the parts.......or a photo. Is the cable attached to the cluster.....
i got the truck three months ago and it didnt work. it was unhooked
from the cluster, I hooked it back up and it dont work, it dont
jump or anything...
PLC7.3, thanks much for posting that link. maybe that's why i couldn't get my cable to release 'cause i was squeezing BOTH sides of the do-hickey. not with pliars though, couldn't get anything but my hand in there... should be able to change out cable now with that help.
