Sponsored by: Auxito
Suspecting Bad Cats
Old Feb 25, 2008 | 05:51 PM
rednekrebel28's Avatar
rednekrebel28
Unhappy Suspecting Bad Cats
I just recently bought a 2003 f150 5.4L with 93,000 miles. Truck runs great but seems to be lacking alot on power. It now has 101,000 miles. So i had flowmasters put on, and sounded good but quiet. Next to the same truck with same motor with same exhuast, my truck was alot quieter. So i decided to cut the system off after i got rear ended and collasped the tail pipes to almost closed. When i cut it off, i was expecting to hear a loud rumble, deep exhaust, insted, i got a low rumble that seems to come from a 6cyl. I suspect the cats maybe clogged. Also, when the truck first starts up, on a 70 degree day, it sounds good, but after the truck gets a little warm, the sound of the nice exhaust is completely diminished. Like the cats are getting warm and blocking airflow. I know theres a way to test backpressure. Any advice, ways to check the pressure, ect. Something to help, cause i really suspect the cats are clogged. Thanks
Old Feb 27, 2008 | 11:06 AM
150mudder's Avatar
150mudder
dont know if youve already done this, but get a rubber hammer and tap on the cat. sometimes if they are clogged then they will rattle internally letting you know the interior has fell apart and is clogging the exhaust. also, pull out a downstream o2 sensor and see if you can see any cat material that has been caked onto the tip of the o2 sensor.
Old Feb 27, 2008 | 12:14 PM
dieselbogging's Avatar
dieselbogging
Take out the O2 sensor out ahead of the convertor and install a back pressure tester. Its pretty much the best way to check.
Old Feb 27, 2008 | 08:05 PM
rednekrebel28
What would the normal pressure reading be if tested at the upstream 02 sensor? I thought that even anything above 7psi is bad, but i am not for sure
Old Feb 28, 2008 | 07:17 AM
dieselbogging
there should be next to nothing really. I think i heard 1-3 psi is acceptable.
TrevorP
41
Sep 3, 2007 09:23 PM
wtschwartz
Jan 19, 2007 09:33 AM
maticuno
Exhaust Systems
May 2, 2005 07:35 PM
dougg
Exhaust Systems
Oct 21, 2003 08:28 AM
shuttlevalve
Exhaust Systems
Oct 15, 2003 10:26 AM
