Screaming whistle
Old Feb 26, 2008 | 08:08 PM
TXHillCountry's Avatar
TXHillCountry
Originally Posted by Green_Monster
I know I am a minority here but the wrapped down pipe ( stock) is nice for me cause in cab whistle is down to a minimum, I do know the aftmrkt dp is the best way to go in general but my setup works for me. In nicer weather I may go for it, but right now I am up 2 mpg and can't complain at all. how many mpgs will the aftrmrkt downpipe add......probably not a sig diff on my stock rig but that is my opinion.
Yeah, I agree that the downpipe by itself is not a significant power/mpg difference. They generally get changed out if you're doing the entire exhaust.
I was worried about the in-cab whistle noise at first, but it's really only noticeable as it spools up. Once you reach your target MPH, such as cruising down the road, the boost drops off and the whistle drops significantly.
Old Feb 26, 2008 | 09:10 PM
Green_Monster's Avatar
Green_Monster
TX is right on that point 100% Its only loud when you spool it up and get it pushing air.
Old Feb 26, 2008 | 11:57 PM
davinh19's Avatar
davinh19
I agree tx is right on, but that is the problem. Nothing beats the sound of the engine and turbo when she's opened up. The times I am trying to quite down are creeping through parking lots and going 30 through neiborhoods when the turbo is just about spooled up.
If I am correct in my thinking, putting the cat back on will quite it down the most but putting a mbrp muffler will give it a smooth tolerable pitch.
Old Feb 27, 2008 | 05:12 AM
Green_Monster
install the muff leave the cat off
Old Feb 27, 2008 | 08:15 AM
denman81's Avatar
denman81
either that or put the factory dp back on. The factory dp in our 03 and sometimes 04s had a small resonator that was ment strictly for the turbo wistle built into the pipe. It will silence the turbo alot but you can still hear it alittle.
Old Feb 27, 2008 | 08:36 AM
TXHillCountry
My Banks downpipe has a small resonator on it, but I don't think it does much. Considering how much trouble it was to get the stock dp off and 3x the trouble to get the new dp in, I don't think I'd do it again. I may be way off, but I'd guess the aftermarket dp doesn't do much for you in the grand scheme of things.
Just my .02
TX
Old Feb 28, 2008 | 07:35 AM
dieseldust2's Avatar
dieseldust2
The stock downpipe on a '03 and early '04 has a resonator in it to tone down the turbo. Banks makes one with a resontor to fix the whine.
Old Feb 28, 2008 | 05:09 PM
TXHillCountry
Yeah, like I mentioned, my Banks downpipe has the resonator on it, but I don't think it does much at all.
TX
Old Feb 28, 2008 | 08:26 PM
6.0superduty's Avatar
6.0superduty
you could always trade your 03 turbo for my 04 It whistles pretty loud, but not as loud as the 03's. I want an 03 turbo just for that reason.
Kyle
waystro
47
Mar 26, 2016 01:47 AM
bennya1
6.4L Power Stroke Diesel
Apr 8, 2015 10:50 PM
burns92
Sep 25, 2013 09:28 PM
Redbullz
Jun 9, 2013 07:44 AM
TONKA05'
Jan 6, 2011 08:04 PM
