2 leaky injectors, fix ???
Old Feb 25, 2008 | 12:33 PM
royzell's Avatar
royzell
Question 2 leaky injectors, fix ???
Hi all,
last week I was working on my '84 6.9. It wasn't starting so I tested the glow plugs (7 / 8 were dead) so I replaced those and it fired right up.
However, to get at 2 of them I undid the clamps on the fuel lines to get a socket and extension on. When I put everything back together 2 injectors leaked like a sieve. I have tried replacing o-rings, the plastic 'hat' that covers them, the rubber fuel lines and clamps to those injectors.
It is hard to tell exactly where the leaks originate because a lot of fuel comes out at once.
I'm wondering if unseating the old connection between the fuel line and injector is the problem.
Is there any product like teflon tape (for plumbing) that can be applied to the threads to seal that connection ?
Any other ideas ?
Thanks
Old Feb 25, 2008 | 05:16 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Not understanding where you unhooked the clamps from.
Did you remove the line nuts?
Or are you talking about the line clamps that hold all the injection lines together?
Old Feb 25, 2008 | 06:02 PM
royzell's Avatar
royzell
Hi Dave,
yes, by clamps I meant the ones that bunch the lines together. I didn't remove the injector lines until after I started the truck and saw the leaks. The two were then removed to replace o-rings. I guess the rubber ones must be the return lines. I replaced those on both sides of the leaky injector, along with the o-ring cover (hat ?)
'hope that is clear......
Old Feb 25, 2008 | 06:04 PM
tbone91's Avatar
tbone91
Did you use worm-drive clamps on the return lines, or the "cheezy" ones that came with the kit? My experience is that worm-drive clamps that small aren't round enough to work. The ones in the kit really do work.
Old Feb 25, 2008 | 06:18 PM
royzell's Avatar
royzell
I used the 'squeeze with pliers' type clamps, they came with the kit.
Old Feb 26, 2008 | 03:03 PM
royzell's Avatar
royzell
'had a few minutes today, so went out and tried some generic o-rings I picked up. Of the 2 leakers, one is now good. I think it probably needs an entire O-ring, return line kit. It has old lines on it and I noticed there are now a few other 'weepers'.
Appears to be the old story with old stuff, fix one thing and mess up something else. I guess those old return lines were self sealing at this point, before being disturbed.
Anyhow, I was going to change the rear end, front fenders and some little things and sell it as a driver. I think now I'll just save time and part it out. It is a good runner.
Thanks all.
Old Feb 27, 2008 | 12:28 AM
Dave Sponaugle
If you are leaking fuel by the clamps that bunch the lines together, there must be a very small hole in the injection line.
About 2000 PSI pressure on those in round numbers.
Old Feb 27, 2008 | 09:11 AM
royzell's Avatar
royzell
Thanks Dave,
The leaks are all at the injectors, on top and around the return line area. It is either coming from the return lines / o-rings or where the steel fuel lines screw on to the injector. The return lines are very old. They may have been 'self sealed' with grease, etc. until I disturbed them. ??
Old Feb 27, 2008 | 10:52 PM
Dave Sponaugle
The rubber O rings under the tees get to hard to reseal if they are disturbed.
It don't take that much hot fuel through the return line before new O rings will not reseal.
I have a few things I always advise about return lines,
If you disturb the return lines, replace the O rings if they are more than a week old.
If the are old, cracked or painted grey, replace them all, the cost is small and the amount of trouble they can give you will drive you nuts.
Old Feb 27, 2008 | 10:59 PM
royzell's Avatar
royzell
Thanks Dave,
yeah this thing almost drove me nuts
I think a complete set of new o-rings and a return line kit will probably fix it.
tlk401
1983 - 2012 Ranger & B-Series
Dec 13, 2022 02:50 AM
coletrain777
Jan 6, 2011 06:20 PM
ttexastim
24
Nov 17, 2010 03:38 PM
72f2504x4390
Jul 1, 2007 11:10 AM
ddb
Oct 23, 2005 11:31 PM
